Rsx injectors ...high or low impedance
You know I'm not positive but being OBD2 I would assume that they are high impedance... I've looked over the RSX engine bay and haven't seen any resistor pack which reassures me that much more... You working on an EG with a K series too, hehe... Not to jack your thread but does anyone know what cc/min the K series and F20C injectors are rated at... Thanks in advance, and bump just incase i'm wrong about the impedance... Latez
if you have a multimeter you can set it to ohms and test the injectors. b16a low impedance are about 2.6 at 200 and my holley high impedance injectors are at 13.1 at 200 hint the high and low impedance. all you do is touch the two probes on the two clips/wires and get a reading.
