Closed loop and O2 sensor?
I see. So I won't throw a code and go into limp mode if I take out the primary O2 and put a wideband O2 in its place? Thanks.
I dont know what the difference is between the wideband and a regular O2 is but if you take out your O2 you cant go into closed loop without a signal. it will put you in limp in unless the hondata does some kind of miracle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hondaLS »</TD></TR><TR><TD CLASS="quote">I dont know what the difference is between the wideband and a regular O2 is but if you take out your O2 you cant go into closed loop without a signal. it will put you in limp in unless the hondata does some kind of miracle.</TD></TR></TABLE>
I don't want it to go into closed loop. Hondata has an option to disable closed loop. But I don't know if I still need the O2 sensor plugged in after disabling closed loop. Oh well, I guess I'll just have to try and see.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan »</TD></TR><TR><TD CLASS="quote">why not just have both? I'm sure its better then just the WB.</TD></TR></TABLE>
Adding another bung for a wideband O2 = more work.
I just want to tune with the wideband O2 in place of the primary O2, and then plug back in the primary O2 after.
well no matter what you'll have to tune with the WB. I'm just sating why eliminate the primary. put them both in and be done with it
madman604
Apr 29, 2003 01:44 PM
