what would cause the ECU to pull timing?
Old Jul 22, 2003 | 04:14 PM
fastwanabe's Avatar
Default what would cause the ECU to pull timing?
I've been having this hesitation and it feels as if the timing were being pulled, what would cause that?
Modified by fastwanabe at 5:06 AM 7/23/2003
Old Jul 22, 2003 | 07:20 PM
fastwanabe's Avatar
Default Re: what would cause the ECU to pull timing? (fastwanabe)
Old Jul 22, 2003 | 07:33 PM
b16ahybrid's Avatar
Depends on what you have done.
Pinging will cause the ecu to pull timing, or even a code will cause it to pull timing.
If you have a knock sensor it will pull timing as it detects pinging/knock.
maybe your car is runing lean, it would feel the same (power levels off early)
Old Jul 22, 2003 | 08:07 PM
fastwanabe's Avatar
Default Re: what would cause the ECU to pull timing? (b16ahybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid &raquo;</TD></TR><TR><TD CLASS="quote">Depends on what you have done.
maybe your car is runing lean, it would feel the same (power levels off early)</TD></TR></TABLE>its a totally stock H22 with I/E and FPR set @ 40psi.
Old Jul 22, 2003 | 09:21 PM
b16ahybrid's Avatar
Do you have any codes? Even if the cel isn't on check for a code.
have you played with the fuel pressure? It's still close to stock so i doubt thats the problem. have you done a tune up lately? change your plugs,cap, and rotor.
be18see1
Apr 9, 2008 05:32 AM
AnAccordIsForever
Nov 13, 2007 08:31 AM
dean2
Dec 27, 2006 11:21 AM
sleeperb16a
Nov 19, 2004 07:32 AM
toooslow
Apr 24, 2003 04:24 PM
