coolant temp sensor in z6 swap...
Old Jul 22, 2003 | 03:01 PM
shorty91's Avatar
Default coolant temp sensor in z6 swap...
d15b2 block
d16z6 block
were does this sensor move to on the z6 block?
Old Jul 22, 2003 | 03:08 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: coolant temp sensor in z6 swap... (shorty91)
It's not in the block.
That sensor is in the thermostat housing.
It also uses a different plug. You can run the wires from the back of the block to the thermostat switch.
Old Jul 22, 2003 | 03:25 PM
shorty91's Avatar
Default Re: coolant temp sensor in z6 swap... (Spaceballs the lunch box)
were is the thermostat housing on the z6?
Old Jul 22, 2003 | 03:28 PM
Malgerus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shorty91 &raquo;</TD></TR><TR><TD CLASS="quote">were is the thermostat housing on the z6?</TD></TR></TABLE>
Where the upper radiator hose attaches to.
Old Jul 22, 2003 | 03:30 PM
shorty91's Avatar
Default Re: coolant temp sensor in z6 swap... (Mr. S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">
Where the upper radiator hose attaches to.</TD></TR></TABLE>
under the distributor??
Old Jul 22, 2003 | 03:32 PM
No Big Whoop
Man, go look at the engine.
You only have ONE place where you can plug a radiator hose AND find a sensor in the same spot.
Old Jul 22, 2003 | 03:46 PM
Timmah!!'s Avatar
Ummm. Correct me if I am wrong, but I think it is the lower radiator hose that attaches to the thermostat housing.
Old Jul 22, 2003 | 03:57 PM
Malgerus's Avatar
Default Re: coolant temp sensor in z6 swap... (azroth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azroth &raquo;</TD></TR><TR><TD CLASS="quote">
Ummm. Correct me if I am wrong, but I think it is the lower radiator hose that attaches to the thermostat housing.</TD></TR></TABLE>
You're right, my bad. Been a while since I've had to deal with this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
Man, go look at the engine. You only have ONE place where you can plug a radiator hose AND find a sensor in the same spot.
But Spaceballs, he'd rather stay here and pick your brain.
Old Aug 22, 2003 | 12:38 PM
crashtest Sonny's Avatar
is the sensor plug brown on the thermostat housing?
Old Aug 22, 2003 | 01:01 PM
mntuner2's Avatar
Thats odd, the z6 I got had a hole allready there but with a allen head on it. You can drill out the bottom of the hole and use a tap to put new threads on it. Just dont drill too deep or you may cause damage to the cylinder wall (not likely, but it is bad to tempt fate) If I am not mistaken, there are many spots where you can mount the b2 sensor just make sure the sensor threads in smoothly and its for coolant and not oil! Last you can use the z6 sensor behind the distributor on the thermostat housing. two wire, in coolant flow (obviously).
Old Aug 22, 2003 | 03:20 PM
Default Re: coolant temp sensor in z6 swap... (mntuner2)
is the sensor brown?
Old Aug 25, 2003 | 08:02 PM
mntuner2's Avatar
Default Re: coolant temp sensor in z6 swap... (4g_civic_si)
I believe the sensor on the t-stat housing of the z6 is brown.
Old Aug 25, 2003 | 08:29 PM
Timmah!!'s Avatar
On my D15b, I just took out the switch from my old motor and put it on the new one, but you will be better off connecting it to the stock one on the motor.
Mikey3000
Jun 23, 2008 04:31 AM
mr. carpenter
Apr 10, 2005 08:39 AM
mini-cRx
12
Oct 29, 2003 12:06 PM
Artful Dodger
Jul 9, 2003 10:23 PM
