wiring headlights for JDM front end..
Old Jul 22, 2003 | 02:25 PM
xXx Justin xXx's Avatar
Default wiring headlights for JDM front end..
there are 3 wires on the h4 bulbs for the new jdm front end on my friends crx
(.:s h a w n d:.) and there are only 2 wires on the stock bulbs? what needs to be done to make these work. thanks
Old Jul 22, 2003 | 02:49 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: wiring headlights for JDM front end.. (SOHC Beast)
You have 4 wires on the US headlights. 2 for low and 2 for high.
So since the JDM uses only one bulb you have to take the hot wire from both US bulb connectors and one ground, your pick.
Then just play trial and error until you get them to work right.
That's what i did back when I instralled my JDM front end.
Old Jul 22, 2003 | 03:12 PM
andrew dc's Avatar
Default Re: wiring headlights for JDM front end.. (Spaceballs the lunch box)
does the high beam indicator come on when you turn on your head lights? mine is on but faint....
Old Jul 22, 2003 | 03:18 PM
No Big Whoop
Default Re: wiring headlights for JDM front end.. (andrew ef)
Yes, it works fine.
I think you might have a ground problem on your dash.
Old Jul 22, 2003 | 04:59 PM
Full-Race Henry's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC Beast &raquo;</TD></TR><TR><TD CLASS="quote"> there are 3 wires on the h4 bulbs for the new jdm front end on my friends crx
(.:s h a w n d:.) and there are only 2 wires on the stock bulbs? what needs to be done to make these work. thanks</TD></TR></TABLE>
They should all be color coded. All i did was hook up both grounds to the one wire on the h4h and then hooked up the wires with the same colors. At least that is the way i did it on my car.
Old Jul 22, 2003 | 06:56 PM
.ShawnD.'s Avatar
Default Re: wiring headlights for JDM front end.. (EF8_Fan)
yep eveything worked out except now i gotta figure out how to wire up my foglights and sence they didnt send me my bumper lights i gotta call them up tommorrow ..
once again HT members pull threw .. i woud be lost with out you guys
bb4 jdm lude
Apr 24, 2007 08:52 AM
90h22ef
Dec 30, 2006 08:52 PM
deanh8
Jul 22, 2006 11:07 AM
Beezle
Aug 24, 2005 10:49 PM
kim_2_da_chee
Jun 23, 2005 09:32 AM
