D16A vs D16Z oil pan question
Old Jul 22, 2003 | 01:35 PM
RStoR's Avatar
Default D16A vs D16Z oil pan question
Are a D16A and D16Z oil pan/pick-up interchangeable?
Old Jul 22, 2003 | 02:03 PM
Garrett's Avatar
Me too I want to know
Old Jul 22, 2003 | 02:16 PM
altoid's Avatar
Default Re: (Garrett)
most certainly
Old Jul 22, 2003 | 03:20 PM
Timmah!!'s Avatar
Default Re: (altoid)
Now, is there any benifits from doing so?? Or do you just have the Z6 oil pan and need a new pan??
Old Jul 22, 2003 | 03:41 PM
biggdogg's Avatar
Default Re: D16A vs D16Z oil pan question (RStoR)
no they are not the same !!! they will interchange but if you put a a6 pan on a z6 block you will have clearance issues with the 4-2-1 stock header . the a6 factory header is 4-1
Old Jul 22, 2003 | 07:31 PM
RStoR's Avatar
Default Re: D16A vs D16Z oil pan question (biggdogg)
Thanks! Long story short....I'm looking into a baffled oil pan for road racing and a friend in "the know" asked if they were interchangeable because evidently he has info a D16A pan rather than D16Z pan which is the motor I have. I'll be using a custom race header so OE clearances are not an issue.
Edit: z6 pick-up works with a6 pan or does it need to be swapped too?
Old Jul 22, 2003 | 09:09 PM
DJ_SaNdOz's Avatar
I think that the pickups are different, or they are located slightly different. I am trying to recall a previous post, so I could be wrong.
Old Jul 26, 2003 | 08:59 PM
JDMs1eeper's Avatar
Default Re: D16A vs D16Z oil pan question (DJ_SaNdOz)
I think the pickups are located differnt. My Moroso pick up for the z's do not work with the new a6 motor i have.
Old Jul 26, 2003 | 11:03 PM
Noahk's Avatar
Default Re: D16A vs D16Z oil pan question (Typesi2nv)
The oil pick ups are different. I think that the z6 pick up is larger, so the a6 oil pan probably won't fit a z6. But a z6 oil pan will probably fit a a6.
Frost7177
Aug 30, 2009 09:37 AM
sanegb16
Jun 28, 2008 08:20 AM
maxogsr
Jun 1, 2008 03:31 PM
silverboost
Jan 18, 2006 09:19 PM
JCracer723
Jun 6, 2003 10:37 AM
