wire coming out of vtec solenoid, where does it go to?
Old Jul 22, 2003 | 11:47 AM
Propulsion's Avatar
Default wire coming out of vtec solenoid, where does it go to?
I bought a ef w/ a b17 swap, and the wire used to attach to a tach, but the tach was taken out. Now the wire just hangs from the vtec solenoid w/ nothing to attach to. what should I do w/ it?
Old Jul 22, 2003 | 12:05 PM
RAWB's Avatar
Default Re: wire coming out of vtec solenoid, where does it go to? (SilverCIVIC96)
If it's actually going to the VTEC solenoid, then that is the wire used to activate it. The tach is typically tapped off the wire from the distributor. Your VTEC isn't kicking in is it? Check the ECU with a wiring diagram(believe it's pin A8) If that's empty, simply run the VTEC solenoid wire to that pin.
Modified by RAWB at 1:58 PM 7/22/2003
Old Jul 22, 2003 | 12:27 PM
wickedEFguy's Avatar
here you go man I found this
Old Jul 22, 2003 | 12:31 PM
NonovUrbizniz's Avatar
Loved
I'm not exactly clear on what you're asking...
If you're saying there is a loose tach signal wire (that someone other than honda put there) under your hood... I'd suggest following it to the dist. and removing it...
If you're asking about the selonoid wiring I think the others have answered your question.
Old Jul 22, 2003 | 12:47 PM
Propulsion's Avatar
thanks, you guys rock
Ill check the ecu plug when I get home and see if need to route the wire to it.
yeah cant feel vtec as of now.
the tach used to have wires from the distributor, vtec soleniod, fuse box, and groud.
CrooksEK
Jul 23, 2014 11:45 AM
LSVtechnologytur...
Jun 6, 2005 04:04 PM
BluntMan
Jan 3, 2003 09:23 AM
AussieK24
May 29, 2002 11:59 AM
