90mm bore is it possiable??? experts only
i just bought weisco 90mm pistons 12.0.1 from a friend and darton sleeves. will this be able to run on pump gas?? are u going to need to upgrade the ingition?? any other equipment needed to make the motor run propley??
holy, holy, holy, holy.... crap. I'm pretty sure that 90mm isn't possible in a B16, unless you remove everything inside the water jacket, get new sleeves, and just use it as as drag car. But then you're talking about some major $$$ and modification issues.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hungry4popcorn »</TD></TR><TR><TD CLASS="quote">i just bought weisco 90mm pistons 12.0.1 from a friend and darton sleeves. will this be able to run on pump gas?? are u going to need to upgrade the ingition?? any other equipment needed to make the motor run propley??</TD></TR></TABLE>
ain't happening my friend. not on a b- series.
sorry
Greg
sorry
Greg
i have seen an 86 mm bore, but even then they say its hard to seal the hg. but damn a 90 mm bore is freagin huge! show us pics of the pistons please
90mm bore is like NSX size piston.
like everyone else says, i think it would be foolish to try and attempt this feat.
ive heard 87mm bore in a LS block.
87mm can be done on any B-series resleeved, but thats the absolute max..else your sleeves would look like the Audi logo....
mabe yes this could work but you would have to buy a custom crank to move the cylinders apart from each other more so their would be less room between the outside cylinders and the water jacket housing right that could work
but you would have to swallow the big one, and they usally like alot of cash also
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_type_r93 »</TD></TR><TR><TD CLASS="quote"> mabe yes this could work but you would have to buy a custom crank to move the cylinders apart from each other more so their would be less room between the outside cylinders and the water jacket housing right that could work
It is impossible, even with offset bore, cylinder head combustion chamber need alot of work and depend how much offset.
Offset bore sleeves is for boost.
If you want "HUGE BORE NA", build a H-Series + deck plate or K-series.
</TD></TR></TABLE>It is impossible, even with offset bore, cylinder head combustion chamber need alot of work and depend how much offset.
How you going to move the mains on the block?
Not possible...
Maybe one day someone will come out with an aftermarket block that has bigger bore spacing and will support a larger bore, but nothing would be OEM in there.
Suprdave
Not possible...
Suprdave
You wouldn't get a custom crank, all you need with an offset bore block is offset extra thick rods.
</TD></TR></TABLE>You wouldn't get a custom crank, all you need with an offset bore block is offset extra thick rods.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Robb »</TD></TR><TR><TD CLASS="quote">I would have to say no. 90mm in a prelude motor is pushing it.</TD></TR></TABLE>
ok 87mm is pushing it on a allmotor engine 90mm will not, WILL NOT seal you will have more trouble with that setup than you will with anything else.
mike
mike
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infamousLSVTEC »</TD></TR><TR><TD CLASS="quote">
mike</TD></TR></TABLE>
LOL. I've seen a 90mm H-series Road race motor do some serious damage. So, it seals just fine.
MAX_CFM I love AutoCAD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pelican »</TD></TR><TR><TD CLASS="quote">
im pretty sure he was talking about B-Series motors...
</TD></TR></TABLE>im pretty sure he was talking about B-Series motors...
