89 crx si engine code light on ecu stays on???
Old Jul 22, 2003 | 10:09 AM
hybridtech's Avatar
Default 89 crx si engine code light on ecu stays on???
The LED light on the ECU stays on. What does that mean? ECU is bad?
I just did a mini me swap and the car will not start. Only wiring that I messed with is the dizzy and injectors. I tried the 98 ex dizzy first then I had to rewire the PM6 dizzy back on. I checked the igniter and the coil they checked out good. I changed the rotor and the cap, but I think they sold me the wrong one. I have a TEC dizzy and I think they sold me the cap and rotor for the other dizzy. Any suggestions? I have compression, gas, timing is set correctly, BUT NO SPARK.
Modified by hybridtech at 1:47 PM 7/22/2003
Old Jul 22, 2003 | 10:10 AM
crxman00's Avatar
Default Re: 89 crx si engine code light on ecu stays on??? (hybridtech)
Bad ECU
Old Jul 22, 2003 | 11:29 AM
hybridtech's Avatar
Default Re: 89 crx si engine code light on ecu stays on??? (crxman00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxman00 &raquo;</TD></TR><TR><TD CLASS="quote">Bad ECU</TD></TR></TABLE>
Man that was fast. So you think I should get a new ECU. It was working before the mini me swap. I guess I could of messed it up if I wired up the dizzy wrong.
I'll try it and see what happens.
Thanks.
zcsport
Jul 27, 2007 09:01 PM
curtis318b16
Jul 25, 2007 09:38 AM
USDM 4G VTEC
Jul 3, 2002 09:24 PM
ZColeon
Oct 22, 2001 06:48 PM
