Compression Test, finally got around to doing it.
Old Jul 22, 2003 | 08:43 AM
Austin's Avatar
Default Compression Test, finally got around to doing it.
I headed over to Chris's house to do a valve adjustment(thanks Chris, took us ~10 minutes with both of us working on it) and since the car was cold and Chris had a compression tester we decided to test the compression. I'd never checked compression, so the opportunity presented itself and we took the 10 minutes to check it out.
Standard procedure when doing a compression test; we unplugged the injector ground, and disconnected the distributor harness, 5 cranks, full throttle, we checked each cylinder twice.
Mods that matter in this test:
Mugen headgasket(Per Mugen +0.4 CR)
Toda Cam Gears, +5, +5(net of +3.5, +3.5 for headgasket)
Mileage 58,400(almost forgot this )
Since we tested each cylinder twice, there are two numbers listed for each cylinder:
#1 - 245, 250
#2 - 250, 250
#3 - 245, 250
#4 - 245, 245
Looks like the numbers are fairly healthy
Have a good day
Austin
Old Jul 22, 2003 | 08:53 AM
Cal's Avatar
Cal
Default Re: Compression Test, finally got around to doing it. (Austin)
Strong numbers
Old Jul 22, 2003 | 09:36 AM
ScorpioX's Avatar
Default Re: Compression Test, finally got around to doing it. (Cal)
those are high numbers... how much PSI would a stock ITR have usually?
did anyone did a compression test on a stock internal itr?
thanks
Old Jul 22, 2003 | 09:56 AM
iperez's Avatar
I never did a "before" test on my ITR but with a Spoon 2-ply head gasket and everything else stock I am running 235psi flat across the board on all 4 pistons. My AEM sprockets are at 0,0 right now, am I going to see an increase in compression when I tune them ??
Old Jul 22, 2003 | 09:58 AM
CPR's Avatar
CPR
Nice numbers but aren't you supposed to do a compression test when the engine's at operating temp?
Old Jul 22, 2003 | 10:15 AM
Willard's Avatar
Looks 'close' to mine.
https://honda-tech.com/zerothread?id=176578
Will
-who re-tested recently... but read the gauge wrong. :hamma:
Old Jul 22, 2003 | 10:16 AM
Chris's Avatar
Default Re: Compression Test, finally got around to doing it. (CPR)
My compression test was done on my STOCK motor with the same tester, and same conditions... it was near 225.
once I did the CTR pistons and Mugen gasket, the numbers were up around 270 before break in.
Old Jul 22, 2003 | 10:17 AM
Chris's Avatar
at operating temp and oiled up, the numbers would be better.
Old Jul 22, 2003 | 10:18 AM
ScorpioX's Avatar
Default Re: Compression Test, finally got around to doing it. (Chris)
CTR pistons? arent those made for 1.6 L? they fit?
Old Jul 22, 2003 | 10:21 AM
Chris's Avatar
Default Re: Compression Test, finally got around to doing it. (ScorpioX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScorpioX &raquo;</TD></TR><TR><TD CLASS="quote">CTR pistons? arent those made for 1.6 L? they fit?
Yup, they work great for getting the compression up. (I was at about 12.5:1)
No more pump gas.
Old Jul 22, 2003 | 10:23 AM
Austin's Avatar
Yes, they are made for the 1.6L, but it has the same bore, and Chris used the overbore size of 81.25mm, as long as you have your valve to piston clearances set correctly, and the car tuned correctly there should not be an issue with using these pistons.
Austin
Old Jul 22, 2003 | 10:24 AM
ScorpioX's Avatar
wow u learn something everyday....
how much power to they give you ?
thanks
Old Jul 22, 2003 | 10:26 AM
Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScorpioX &raquo;</TD></TR><TR><TD CLASS="quote">how much power to they give you ?
thanks</TD></TR></TABLE>
Stock top end, and JDM OEM 4-1 header... 198 to the wheels, 136 torque.
Old Jul 22, 2003 | 10:31 AM
ScorpioX's Avatar
how much do they CTR pistons go for?
And where is the best place to get them?
thanks
Old Jul 22, 2003 | 10:37 AM
Chris's Avatar
you got IM!
Old Jul 22, 2003 | 10:38 AM
Austin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScorpioX &raquo;</TD></TR><TR><TD CLASS="quote">how much do they CTR pistons go for?
thanks
I buy all of my JDM and most all of my performance parts from Mike at IPS Racing.
Austin
Old Jul 22, 2003 | 01:33 PM
Chubz's Avatar
with CTR pistons and JUN IIIS i was hitting wat past 300psi in every cylinder.
Old Jul 23, 2003 | 12:05 PM
ScorpioX's Avatar
I found a guy that is selling CTR pistons...
i want to make sure they actually are CTR pistons... what markings do i need to look for? or code? is there a site that i can go check?
thanks guys.
Old Jul 23, 2003 | 04:44 PM
Chris's Avatar
Hmmm.. cant remember, Maybe P73 stamped on them?
Old Jul 23, 2003 | 07:37 PM
Chubz's Avatar
no they are stamped PCT
Old Jul 23, 2003 | 08:06 PM
Chris's Avatar
Default Re: Compression Test, finally got around to doing it. (Notorious B.A.G.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Notorious B.A.G. &raquo;</TD></TR><TR><TD CLASS="quote">no they are stamped PCT</TD></TR></TABLE>
ahhh yes.. thanks. Been a while.
Old Jul 23, 2003 | 08:12 PM
Chubz's Avatar
No prob
Old Jul 24, 2003 | 08:41 AM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austin &raquo;</TD></TR><TR><TD CLASS="quote">
#1 - 245, 250
#2 - 250, 250
#3 - 245, 250
#4 - 245, 245
Austin, you're prolly an avid Mobil 1 user !!!
very nice, I hope you never rebuild and just keep adding more mods to your stock motor and break a 200, that would be very cool !!!
Greg
Old Jul 24, 2003 | 09:08 AM
Austin's Avatar
Default Re: Compression Test, finally got around to doing it. (CHEETAH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHEETAH &raquo;</TD></TR><TR><TD CLASS="quote">
Greg</TD></TR></TABLE>
Mobil 1 since ~10,000 miles, I've used Redline 10w30 for the last 6,000 miles, I manage to burn oil at throttle lift regardless if it's Redline, or Mobil 1 10w30, so I'm switching back to Mobil 1.
Power levels...well, I've thought on the Toda A's, or the Skunk 1's but with the more aggressive vtec lobes I'm under the impression that I'll be making a sacrafice in the mid-range since the plot is already smooth with a 3,300rpm crossover, the larger lobes causing a harsher transition would require a higher vtec crossover. We tuned the cam gears for more of a mid-range power level, so I'm under the impression that with retuning of the cam gears for a peakier power level I'll be able to gain some peak whp with a sacrafice of the mid-range. I think that a ported and shaved head along with a redesigned header from John would most likely get me to the 200whp mark on stock cams, and possibly close to the 140ft/lbs. I've also been kicking the idea around of selling off my icebox and investing in the Mugen intake as a few people have tested it locally and had a fair amount of gains over the icebox. But at the moment I'm very happy with how well the car is running, just need to invest in a decent catch can to help with the oil that's making it's way through the PCV system. I'm not going to tear the motor apart until it really needs it, which may be another 2 years when I'll be around the ~120,000 mile area, we'll see what happens between now and then.
Thanks for the encouragement Greg,
Austin
Old Jul 24, 2003 | 12:39 PM
charjacq's Avatar
New User
Hum, I'm 200 psi all around... I hope it's the crappy tester that is not accurate...
Brandon Peters
Oct 18, 2015 05:37 PM
06BlackSi #45
Honda Civic (2006 - 2015)
Nov 22, 2009 06:55 AM
92vxjdm
Aug 15, 2008 05:05 AM
