differences between s1 trannys?
Old Jul 21, 2003 | 11:52 PM
-Racer X-
Guest
Posts: n/a
Default differences between s1 trannys?
how can you tell the difference between a s1 from a 90-91 integra and a b16 s1 tranny?
Old Jul 22, 2003 | 09:58 AM
-Racer X-
Guest
Posts: n/a
Default Re: differences between s1 trannys? (-Racer X-)
bump
Old Jul 22, 2003 | 03:46 PM
-Racer X-
Guest
Posts: n/a
Old Jul 22, 2003 | 04:31 PM
sleeper4dr's Avatar
they look exactly the same going by the case.
you could crack the damn thing open and count gear teeth.
Old Jul 23, 2003 | 08:21 PM
-Racer X-
Guest
Posts: n/a
Default Re: differences between s1 trannys? (sleeper4dr)
well i was wondering if there was a siff in serials or something.
Old Jul 23, 2003 | 10:30 PM
Kataku2K3's Avatar
Exactly as sleeper4dr said, the cases are the exact same but one has shitty gearing for VTEC motors and the JDM S1 is the one most people want... A quick way I test for a JDM S1 is to rotate the mainshaft, place a tick mark (sharpies work well) on the diff to watch for one full rotation... If you have a JDM S1 you should rotate the mainshaft ~14.2 times to get one full rotation of the diff (**only when the car is in FIRST gear) If it comes up less then you most likely either have a Y1 or USDM S1 (nonVTEC)... That's just if you are in a rush, otherwise open up the casing and count the teeth for each gear... Hope this helps a little, Latez
Old Jul 24, 2003 | 01:10 AM
Kwuaymaikrup's Avatar
Which gears do I count and how many teeth am I looking for??? I am having the same problem.
-Ryan
aldracing44
Mar 20, 2008 04:09 PM
SiZ
Aug 23, 2005 01:11 PM
G2integra217
Aug 7, 2005 03:47 PM
JDM DERF
17
Dec 3, 2004 01:16 PM
BigIslandBoi
Mar 23, 2004 06:08 PM
