Rod Ratio.... rods in motors
Old Aug 3, 2001 | 09:49 AM
newspeedR's Avatar
Default Rod Ratio.... rods in motors
i know that the b18b has a shorter rod than the b18c... can you run the b18b rod in the gsr block... since it has a shorter rod, i would assume that it would lower the CR... anyone know anything bout this...
thanks
Old Aug 3, 2001 | 01:37 PM
optiontoo's Avatar
New User
Default Re: Rod Ratio.... rods in motors (newspeedR)
You can't swap the rods because the B18C1 has a rod width of 0.858" and the B18A/B has a rod width of 0.935".
Why would you want to lower the compression on a B18C1 anyway??? Even if you have a turbo, the way to prevent detonation would be through superior engine management (IE a Unichip or Hondata).
eg6madness
Oct 25, 2011 03:47 PM
gutted
Nov 26, 2009 05:51 AM
fast break
Jul 15, 2005 03:37 PM
Screamer
Dec 13, 2001 09:23 AM
