hot hot tanking
Old Jul 21, 2003 | 08:55 PM
wm5holla's Avatar
Default hot hot tanking
does hot tanking ur block make ur motor run better. i mean my boy told me the only reason to hot tank is so it will look pretty
Old Jul 21, 2003 | 09:56 PM
MaxBoost's Avatar
New User
Default Re: hot hot tanking (wm5holla)
I like to do this when im building a motor, but it doesn't add hp or anything..
it will make the block look new, and it will clean on the inside as well. If there's oil in there, the oil can attract and hold dirt, dust, or metal and keep it in your motor while your assembling it.
You get your motor looking nice, clean of all metal shavings that might have occured in the machine shop, ready to be assembled in a clean room if your **** ( i am)...it's worth what they charge and not a bad idea, but not absolutely necessary or anything.
Old Jul 22, 2003 | 08:11 AM
MADEINIRAQ's Avatar
Default Re: hot hot tanking (MaxBoost)
what do places usually charge for hot tanking
Old Jul 22, 2003 | 10:18 AM
IN VTEC's Avatar
Default Re: hot hot tanking (madeiniraq)
Our's was $35 for the hot tanking at Schmidt Racing.
Old Jul 22, 2003 | 12:44 PM
YOUR DADDY's Avatar
definetly worth it for the price, gives you some bling and clean the inside where it really counts.
Old Jul 22, 2003 | 05:47 PM
wm5holla's Avatar
the shop in Jersy where alot of people go to they want 65 for hot clean and honing is 65 too the shop is called EDDIES THE NUMER IS 732 727 2325
Old Jul 22, 2003 | 05:48 PM
jmkahool's Avatar
Old Jul 22, 2003 | 09:33 PM
civicsitek GanGsTa's Avatar
Default Re: (jmkahool)
we charge $35 for hot tanking a 4 cylinder block as well
Old Jul 23, 2003 | 12:37 PM
joe_bocc's Avatar
Default Re: (civicsitek)
Having a clean block may also help you find and/or keep track of fluid leaks that you may encounter.
Old Jul 23, 2003 | 01:58 PM
NA_crix's Avatar
can you hot tank a tranny?
Old Jul 23, 2003 | 04:52 PM
ProTreeCRX's Avatar
Default Re: hot hot tanking (YOUR DADDY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YOUR DADDY &raquo;</TD></TR><TR><TD CLASS="quote">definetly worth it for the price, gives you some bling and clean the inside where it really counts. </TD></TR></TABLE>
from bay area? what shop in bay hot tanks?
dizzyroc88
Jun 25, 2010 10:39 PM
Peter Brady onlyonweekndz
Nov 26, 2007 12:55 AM
albert
Dec 30, 2004 07:04 PM
johnzm
Mar 7, 2004 12:05 PM
Kwuaymaikrup
Jan 22, 2003 06:15 AM
