dash and tail lights out - help
Old Jul 21, 2003 | 08:23 PM
fuguman's Avatar
New User
Default dash and tail lights out - help
the tail and dash lights on my 2000 accord are out after i put in my new stereo
i wired the ground on the dimmer ground to the dimmer + and now the lights dont go on. let me know if u know what the problem is. i checked the fuses that were listed in the manual and they are all fine.
HELP!!!!!
oh and the head lights on beep is not there either .... everything else is working
Old Jul 22, 2003 | 02:11 AM
D114's Avatar
Default Re: dash and tail lights out - help (fuguman)
Disconnect the dimmer on the radio then check all the fuses once again... it really sounds like a fuse problem. Leave the radio disconnected and try again? I guess you did that also though.... I won't doubt that.
Try checking the "dimmer relay". Check to see if the relay still works. If in doubt, borrow someone elses relay. On my 4g, its located under the hood.
Old Jul 24, 2003 | 12:44 PM
98blkaccord's Avatar
i had the same problem, i even checked all the fuses too...and in the end after getting tickets for no lights and crap the problem was a blown fuse...trust me its a blown fuse or relay
Old Jul 24, 2003 | 01:39 PM
fluxion's Avatar
amin n'rangwa edanea
you wired the ground for your dimmer to the dimmer wire on your radio harness? i'm assuming you've already rewired that cuz that would explain why your interior lights aren't working anymore.
if you have already done so and the problem is still persisting then i would assume it's a blown fuse, if not then recheck your wiring. in my 5th gen the dimmer wiring doesnt affect the tailight's circuitry in any way so you might have something else wired incorrectly.
Old Jul 24, 2003 | 02:50 PM
Shtryfe's Avatar
Check the fuse labeled small lights, im pretty sure thats the one for the dash and tail lights, even if the fuse doesnt look blown test it for continuity as sometimes they blow with no visual effects.
Old Jul 25, 2003 | 04:37 AM
fuguman's Avatar
New User
it was the fuse thanks every one
on the passanger side BTW...i'll try to post the # for future it was a 10A i believe...not that it says much
Old Aug 7, 2003 | 04:04 PM
crafty's Avatar
I have the same problem, which fuse did you find that was blown?
I have checked them all and i didnt find any that were blown
92honda92
Sep 27, 2007 07:48 AM
wsuozzie
Nov 15, 2006 07:06 AM
peepintom523
Jul 28, 2006 09:35 AM
xxx
Oct 31, 2005 06:57 PM
philipwk
Oct 14, 2005 06:49 AM
