Skunk2 ECU conversions
Old Jul 21, 2003 | 08:00 PM
YACITH's Avatar
Default Skunk2 ECU conversions
I recently purchased a Skunk2 chip from some guy off Ebay. It probably isn't worth a penny but I only paid $15 so if it doesn't work, no big loss. My question is will this chip only work with VTEC ECUs? I have a 93 DX hatch in my back yard that I'm stripping to race and the motor is no good to me. I know the ECU is in great condition and if I can take that off and chip it to put in my '98 Civic then that'd be great. I know I need a harness and I already have one but I just want to know if I can chip that ECU and save money instead of buying a used one of Ebay?
Old Jul 21, 2003 | 08:31 PM
SuperSteve's Avatar
New User
25 Year Member
Default Re: Skunk2 ECU conversions (YACITH)
If it is a VTEC chip then yes it will only work on a VTEC ecu such as a P28 or P72 if OBD1.
Old Jul 21, 2003 | 09:36 PM
Kataku2K3's Avatar
Default Re: Skunk2 ECU conversions (SuperSteve)
Your ECU in your '93 DX should be a P06, (either containing the 11F0-1500 or 1720-1500 board) these are both used as SOHC EX/Si ECU's (P28) and can be converted to VTEC fairly easily... You'll need your standard 20 pin DIP chip, your SK2 ROM, a 10K resistor, and a couple 103Z ceramic caps to do the conversion to DOHC VTEC but all you need to go from the nonVTEC (P06) --> to --> VTEC is to get a VTEC 5 pin transistor (S5050), jump J10, add a cap to C60 and on the 11F0 board a 3 pin transistor to Q101... I'm still working on a more detailed write up but this is pretty straight foreward... I also recommend socketing 27256 as you may want to change your ROM later on down the road (this just makes it easier)... Hope this helps... Latez
Old Jul 22, 2003 | 01:52 PM
YACITH's Avatar
Default Re: Skunk2 ECU conversions (Kataku2K3)
You are ******* awesome! Keep me informed as to when you have the instructions finished. Thanx.
Rooftop voter
Mar 21, 2007 06:13 AM
92hatchling
Mar 9, 2006 06:40 PM
mtber
Nov 1, 2004 10:08 AM
eL
Aug 16, 2004 02:10 AM
kenji
Jan 28, 2002 06:41 PM
