NEED HELP ASAP: IACV cel and buggy idle
Old Jul 21, 2003 | 04:19 PM
chameleon's Avatar
Default NEED HELP ASAP: IACV cel and buggy idle
hey im hoping one of you guys can help me out with this. i was running my B16a2 motor in my 95 eg with a PR3 ODB1 computer and the thing ran smooth as hell, no cels and no problems.
i now have the motor in my 98 ek and im using a P28 w/ hondata. the wiring is all correct and i have swapped the IAC with another and i still have the exact same problem.
symptoms: when i start the car it will rev to 2k like normal then come down quick to 1k then slow creep to 1.5k and stay there.. if i drive around the idle will start bopping slowly from 1.7 to 1.5k its not even a HUGE surge but just bops in place.
when it was in the EG i had perfect idle @ like around 800rpms. so i know the IAC wasnt broken, the TB wasnt messed up or clogged and its a 2000 motor. i dont know what the prob is.
can anyone shed some light on this?
AIM: chamelieon
btw now im running a turbo but that should really affect anything.
Old Jul 21, 2003 | 04:28 PM
ekb18c's Avatar
Default Re: NEED HELP ASAP: IACV cel and buggy idle (chameleon)
was hondata tuned for your car?
Old Jul 21, 2003 | 04:46 PM
chameleon's Avatar
Default Re: NEED HELP ASAP: IACV cel and buggy idle (ekb18c)
yes it has been street tuned, i will be going to the sunday event to PA for dyno tuning.
Old Jul 22, 2003 | 04:25 PM
chameleon's Avatar
ttt
Old Jul 22, 2003 | 04:31 PM
Mr. Softee's Avatar
pull down on the wires that go into the clip, if your idle improves its your clip. also disconnect it and see if it does the same thing.
Old Jul 23, 2003 | 05:03 PM
chameleon's Avatar
Default Re: NEED HELP ASAP: IACV cel and buggy idle (94goldjungsr)
pulled the clip and nothing changed. thing is the wiring is right. ima have to make a plug and wire it directly to the ecu to skip the harness which might be whats at fault.
DanInOttawa
Aug 21, 2014 06:59 PM
Asbill572
Feb 25, 2013 06:55 AM
ja20_eg
Engine Management and Tuning
10
Aug 18, 2012 06:33 PM
debogsr
Dec 20, 2005 10:17 AM
NOPD
May 22, 2002 12:13 PM
