i need a 84mm head gasket asap!
Old Jul 21, 2003 | 02:27 PM
crx1856's Avatar
Default i need a 84mm head gasket asap!
i'm looking for a 84mm head gasket for my gem 84mm b16 block. gem is out of stock.
Old Jul 21, 2003 | 02:54 PM
crx1856's Avatar
Default Re: i need a 84mm head gasket asap! (crx1856)
ttt
Old Jul 21, 2003 | 02:55 PM
liam821's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx1856 &raquo;</TD></TR><TR><TD CLASS="quote">i'm looking for a 84mm head gasket for my gem 84mm b16 block. gem is out of stock.</TD></TR></TABLE>
Can you use a b20 gasket from honda? Or are they different? You can put a b16 head on a b20 block so i would think you could use the b20 head gasket on a b16 block.
liam
Old Jul 21, 2003 | 03:08 PM
Boostfed's Avatar
New User
Default Re: i need a 84mm head gasket asap! (liam821)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liam821 &raquo;</TD></TR><TR><TD CLASS="quote">
liam</TD></TR></TABLE>
No because of the oil supply holes in the VTEC head and block, you can use the B20 Gasket for a B20/Vtec because you plug this hole anyways but on a straight 84mm B16 you need a Cometic gasket or ***gulp** Golden Eagle bored stock gasket. Good luck.
Old Jul 21, 2003 | 03:10 PM
thid92's Avatar
can I haz?
get a B20 headgasket and take it to a local machineshop and bore the vtec hole
Old Jul 21, 2003 | 03:12 PM
Boostfed's Avatar
New User
Default Re: (thid92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thid92 &raquo;</TD></TR><TR><TD CLASS="quote">get a B20 headgasket and take it to a local machineshop and bore the vtec hole</TD></TR></TABLE>
I had thought of that to, try it
Old Jul 21, 2003 | 03:27 PM
liam821's Avatar
25 Year Member
Default Re: i need a 84mm head gasket asap! (Boostfed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed &raquo;</TD></TR><TR><TD CLASS="quote">
No because of the oil supply holes in the VTEC head and block, you can use the B20 Gasket for a B20/Vtec because you plug this hole anyways but on a straight 84mm B16 you need a Cometic gasket or ***gulp** Golden Eagle bored stock gasket. Good luck.</TD></TR></TABLE>
Cool i learn something new everyday!
liam
CW-ITR
10
Oct 5, 2007 11:43 AM
Frank_2.0L
Oct 1, 2005 08:05 PM
Dan-Dillinger
13
Sep 5, 2005 01:39 PM
crx1856
Jul 17, 2003 06:44 PM
GapxGuy
Dec 22, 2002 05:27 PM
