my a/c isnt cold..had my freon recharged and it didnt help, what should i do next?
Old Jul 21, 2003 | 01:56 PM
drdavidge's Avatar
Default my a/c isnt cold..had my freon recharged and it didnt help, what should i do next?
just as the topic says.. i got a 95 gsr with r134a refrigerant, had it professionally sucked out and filled up to correct specs a week ago, but it still isnt that cold especially when its hot out. i go in my parents cars or my friends cars and their ac is like ICE cold to the point i cant wear shorts and a beater without being cold. mine just feels like a fan of slightly colder then outside air. the compressor turns on like its suposed to, and i dont know what to check next. any ideas? please help, its hot and black cars with black leather really sucks in the heat.
Old Jul 21, 2003 | 02:03 PM
mickey513's Avatar
Default Re: my a/c isnt cold..had my freon recharged and it didnt help, what should i do next? (drdavidge)
Sounds like you have a leak somewhere since you had it recharge a week ago. The shops can put a red dye that can trace the leak in the ac system.
lol The AC on my other car, a 03 rsx-s is COLD. Even on the lowest setting I can't stand it.
Modified by mickey513 at 8:04 PM 7/23/2003
Old Jul 21, 2003 | 02:26 PM
Loccster's Avatar
Default Re: my a/c isnt cold..had my freon recharged and it didnt help, what should i do next? (mickey513)
another ac topic .. damn the weather
Old Jul 21, 2003 | 02:44 PM
p1ccoloz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mickey513 &raquo;</TD></TR><TR><TD CLASS="quote">lol The AC on my other car, a <U>09</U> rsx-s is COLD. Even on the lowest setting I can't stand it.
wow there out already? psh im still waiting for the 04's! just playin, but yea he's right theres probably a leak somewhere
Old Jul 22, 2003 | 06:47 PM
drdavidge's Avatar
Default Re: my a/c isnt cold..had my freon recharged and it didnt help, what should i do next? (p1ccoloz)
no leak, the freon level and pressure is right where it should be, i have a gauge. even when they recharged the system it wasnt colder that day, it was the same as before itried adding a can myself. if i turn the a/c button off, it does get a lot warmer, so the compressor and ac IS working, but its just not getting cold enough. why would it get just a little cold but not very cold?
Old Jul 22, 2003 | 07:04 PM
azzenco's Avatar
Could be your expansion valve or evaporator core.
When my expansion valve went out the car would get cold for a cycle then it'd blow warm air.
Old Jul 22, 2003 | 08:51 PM
Who Said's Avatar
check the condensor maybe its got something blocking it
Old Jul 22, 2003 | 09:15 PM
drdavidge's Avatar
Default Re: my a/c isnt cold..had my freon recharged and it didnt help, what should i do next? (super-dooper
where are these things to check?
Old Jul 22, 2003 | 09:22 PM
tilt's Avatar
id check the condenser fins. It is in the same spot as the radiator. If they are bent straighten them out. If they look dirty, use pressurized water to clean it off. You can find them at any self-carwash place.
Old Jul 22, 2003 | 09:39 PM
TEGME's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt &raquo;</TD></TR><TR><TD CLASS="quote">id check the condenser fins. It is in the same spot as the radiator. If they are bent straighten them out. If they look dirty, use pressurized water to clean it off. You can find them at any self-carwash place. </TD></TR></TABLE>
Yup, check that, the fins can get bent easily and can get a whole in them relatively easy too.
Old Jul 22, 2003 | 09:47 PM
hi-Powered's Avatar
i wouldn't use a pressure washer because it only bend it some more.use a fin comb which u can get at kragen.
check your system by hooking up a manifold gauge set.you should read about 180-200 psi on the high side and 30-40psi on the low side.if it's low, your low on refrigerant.
Old Jul 23, 2003 | 09:19 AM
drdavidge's Avatar
Default Re: (numbnut)
my pressure is at the proper level. ill check the fins, but i dont think thats it because i tried running a hose though it while everything was on and it got a LITTLE colder but not too much. wtf is a fin comb?
Old Jul 23, 2003 | 11:23 AM
quikB18B's Avatar
Default Re: (drdavidge)
Here try this I had the same problem last month. Whenever you adjust you climate controls there are brackets, with little i think L shaped pieces that move to adjust the temperature. These are located behind the dash(radio) Mine had popped out of its little groove so when i went to turn it colder the swithc on climate control moved all the way, and they bracket moved, but the small piece remained in its position. Thus not allowing for colder air.
Sounds wierd but get a buddy and have him mess with the climate control while you lay on floor of passenger. Check and make sure everything is in tact.
Try this before you spend alot of $ on expensive parts that aren't the problem
Old Jul 23, 2003 | 01:22 PM
drdavidge's Avatar
Default Re: (quikB18B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B &raquo;</TD></TR><TR><TD CLASS="quote">Here try this I had the same problem last month. Whenever you adjust you climate controls there are brackets, with little i think L shaped pieces that move to adjust the temperature. These are located behind the dash(radio) Mine had popped out of its little groove so when i went to turn it colder the swithc on climate control moved all the way, and they bracket moved, but the small piece remained in its position. Thus not allowing for colder air.
Try this before you spend alot of $ on expensive parts that aren't the problem </TD></TR></TABLE>
yea i tried moving the **** manually under the passanger dash, but the same **** happened...still not cold like it should be
Old Jul 27, 2003 | 12:46 PM
drdavidge's Avatar
anyone else?
Old Jul 27, 2003 | 03:27 PM
nsxtasy's Avatar
H-T Order of Merit
Did they try sticking a temperature probe in the vents to measure how cold the air coming out is?
Old Jul 28, 2003 | 10:09 AM
Jay J's Avatar
Prince of Zamunda
Default Re: (nsxtasy)
try putting in that florecent additive. WHen you put the florecsent light it shows where it's been leaking also is the coolent mix correct.
Old Jul 28, 2003 | 11:49 AM
Fuuma0083's Avatar
Default Re: (neuspeed)
Well if he wuz leaking AC you would know just by looking at the "Sight Glass" which would be bubbling if your low, and clear if its full.
Old Jul 28, 2003 | 01:11 PM
drumking15's Avatar
my ac isnt cold either...but if you look at the ac pressure gauge most have a green, yellow and red...and a blue section
i found that if its just at the lowest level before recharhing is suggested i got the coldest air..still not great but...better than having a really full charge that cant compress...the more the freon comprsses the colder it gets...so its not always good to have more...and i reallt dont care anymore my ac is gettin pulled for weight and BOOST!!!
Old Jul 28, 2003 | 03:47 PM
Brian-Brian
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdavidge &raquo;</TD></TR><TR><TD CLASS="quote">just as the topic says.. i got a 95 gsr with r134a refrigerant, had it professionally sucked out and filled up to correct specs a week ago, but it still isnt that cold especially when its hot out. i go in my parents cars or my friends cars and their ac is like ICE cold to the point i cant wear shorts and a beater without being cold. mine just feels like a fan of slightly colder then outside air. the compressor turns on like its suposed to, and i dont know what to check next. any ideas? please help, its hot and black cars with black leather really sucks in the heat. </TD></TR></TABLE>
have the same problem too just replaced couple of hoses and recharged it still not cold enough....feels like just air not COLD air...... if you find out wah's the problem let me know too thanks
Old Jul 28, 2003 | 05:37 PM
RIX982DRLS's Avatar
I had the same problem with my 98 when i bought it last year. i took it to the 2 different acura dealers (criswell + rosenthal) and rosenthal found out that 1 way or another the heat duct was partially stuck open and that's why it was staying hot...it's blowing ice cubes now and it was covered under the warranty(didn't cost a dime)
Old Jul 28, 2003 | 07:43 PM
Brian-Brian
Guest
Posts: n/a
Default Re: (RIX982DRLS)
me no warranty where is heat duct located at??
Old Jul 28, 2003 | 08:17 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdavidge &raquo;</TD></TR><TR><TD CLASS="quote">where are these things to check?</TD></TR></TABLE>
The expansion valve is inside the evaporator housing.
Could also be a clogged reciever/dryer. That's a long aluminum cylinder
on the inside drivers fender under the windshield washer resevoir.
Old Jul 28, 2003 | 08:30 PM
drumking15's Avatar
any one got a diagram...i havent had time to pull out the helms...or even a pic...if i find it in the helms ill post something up
Old Jul 29, 2003 | 08:18 AM
drdavidge's Avatar
Default Re: (drumking15)
so how do we check this stuff?
