Toda Power
my setup is as follows... will i reach 200 mark?
toda a's
12.5 compression
ported and polish intake and exhaust ports
jdm headers
test pipe
vafc
cam gears
pullies
2.5 exhaust
possibly power fc in the near future
will i also be able to daily drive my car with this high compression?
[Modified by flex97itr, 6:44 AM 8/3/2001]
toda a's
12.5 compression
jdm headers
test pipe
vafc
cam gears
pullies
2.5 exhaust
Just get your tuning dialed. Do you have a a air fuel meter? How bout injectors? How bout springs and retainers? ecu? plan on revving to 9?
12.5:1 is pretty damn high for pump gas. You're gonna need a ecu with fat tuning and run bigger injectors so you don't detonate.
[Modified by FAST94GSR, 9:55 AM 8/3/2001]
I would go with a power FC may cost more but you will probably buy it later down the road anyways so might as well go ahead and get it.
My Dad always use to say do it right the first time or never do it at all. Because you end up spending more money if you just did it right the first time.
i will have to retard ignition alot right? btw... what exactly does the j&s do?
12.2 compression on the street is fine, ask steve he is running the CTR pistons and using 92 octane gas, I'm running 12.4:1 and its a daily driver
Flex97ITR, I TOTALLY agree with you. The A's are much better for the street than the B's in my opinion. Awesome midrange and nice peak power around 8200 or so. Combine that with the compression and a nice, close ratio tranny and you're in there. Money.
What power are you making right now mike?
Any time slips?
Any time slips?
I'm not much of a Drag racer (cars setup more for Road racing but I will go to the strip a few times)
No you won't, The J&S monitors for detonation and automatically retards timing either for all 4 cylinders or individually
James
How does it retard timing on an individual cylinder? Actually, how does the J+S work period? I know that it retards timing in case of detonation, but would an Apex timing controller do the same thing?
James
James
I couldn't tell you exactly how the J&S makes the retard happen(though in the wiring it inturupts the wire that tells he ignition to fire the spark) The A'PEXi unit allows you to make changes to the timing, the J&S is a device that reacts to knock and detonation quicker and at a more controlled level than the stock ECU. The newer versions allow you to program in a vaccuum advance on NA cars, and a retard feature similar to the MSD BTM(I think that's what it's called), but a little more advanced.
Austin
must i rebalance my bottom end with ctr's? what about if i utilize del sol pistons. do i still hafta belance the crank... money is an issue here and machine shops are pretty expensive.
