Kakimoto Racing exhuast w/ 22mm sway bar... rub or no?
Old Jul 21, 2003 | 10:55 AM
Mr.DC2TurBo's Avatar
Default Kakimoto Racing exhuast w/ 22mm sway bar... rub or no?
Hi, I have a 01 LS and I'm thinking about getting the 70mm Kakimoto Racing exhuast. I read that LS and type r have the length and the pipping will fit. Anyone can verify this. Also, I have an itr 22mm rear sway bar and I'm afraid that the 70mm (2.75in) will rub against it. Any of you itr have this problem??
Old Jul 21, 2003 | 11:56 AM
Default Re: Kakimoto Racing exhuast w/ 22mm sway bar... rub or no? (Mr.JDM_KiD)
bump
Old Jul 21, 2003 | 12:01 PM
typer193's Avatar
AFAIK, the Kakimoto exhaust is only in JDM length so if you want to make it work with your LS, you'll either have to get a JDM sized cat or shorten the b-pipe to work with your stock cat. As far as fitment goes, I've had no problems with it. In fact, it's probably the best fitting exhaust I've put on the car thus far.
Old Jul 21, 2003 | 01:44 PM
mafay2's Avatar
New User
No, it will not have any problem clear the 22mm rear sway bar at all.
Old Jul 21, 2003 | 05:17 PM
canuck-mx6's Avatar
mine clears my 22 mm sway bar no problems
If you are running a JDM length header, you cat will need to be 12" exactly to fit. That is the length of the test pipe that I am using between my DC Sports JDM style header and my Kakimoto.
Old Jul 21, 2003 | 06:57 PM
Default Re: Kakimoto Racing exhuast w/ 22mm sway bar... rub or no? (canuck-mx6)
Isn't a jdm itr header the same length as LS.. just diameter is different, right?
Old Jul 21, 2003 | 07:45 PM
sil's Avatar
sil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.JDM_KiD &raquo;</TD></TR><TR><TD CLASS="quote">Isn't a jdm itr header the same length as LS.. just diameter is different, right?</TD></TR></TABLE>
cat is a different length
Old Jul 21, 2003 | 07:46 PM
sil's Avatar
sil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by canuck-mx6 &raquo;</TD></TR><TR><TD CLASS="quote">mine clears my 22 mm sway bar no problems
nice looknig exhaust.. i've got the same one and absolutely hate how big the tip is.. not exactly sure why the built that 'shroud' that protects the actual tip..
Old Jul 21, 2003 | 08:06 PM
typer193's Avatar
Default Re: Kakimoto Racing exhuast w/ 22mm sway bar... rub or no? (sil)
Supposedly the shroud is to be a heat shield. Don't know how effective it really is and if it's really needed at all. Thinking about taking mine off. Not a big fan of the huge exhaust tip either
Old Jul 21, 2003 | 08:33 PM
sil's Avatar
sil
Default Re: Kakimoto Racing exhuast w/ 22mm sway bar... rub or no? (typer193)
it could be their way to prevent the bumper from melting if there were fitment problems.. as for fitment problems i'm not sure why but my exhaust hangs too low and off to the side, the flange in the bpipe hits the frame.... i couldn't even find a hangar to bend that would fix (or even create) that problem (something was done a while back to fit in a short shifter)
anyways, i'm off to a stock type of exhaust, i'm sick of the fat tip
Old Jul 21, 2003 | 08:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sil &raquo;</TD></TR><TR><TD CLASS="quote">
cat is a different length</TD></TR></TABLE>
I always see ppl saying that the LS and type r exhaust will fit perfectly. Am I wrong?
Old Jul 21, 2003 | 09:16 PM
mafay2's Avatar
New User
I always see ppl saying that the LS and type r exhaust will fit perfectly. Am I wrong?</TD></TR></TABLE>
USDM ITR and JDM ITR have difference exhaust length because the JDM ITR have shorter cat.
Old Jul 21, 2003 | 09:31 PM
Default Re: Kakimoto Racing exhuast w/ 22mm sway bar... rub or no? (mafay2)
drats... Anyone know what is the length of the LS cat?
Old Aug 15, 2003 | 10:59 AM
BlueTeg's Avatar
17.5"
ekhatchey
May 16, 2010 06:47 PM
streetlights
Suspension & Brakes
Dec 18, 2005 08:56 PM
pearlteg
Dec 27, 2004 02:53 PM
Nfurno
Mar 2, 2004 04:37 PM
