Car does not want to move
Fellas I need your help,
The car starts but doesn't move. I hear a grind when I rev the engine. Is this the clutch or tramission
The car is 95 LS Integra
120,000 miles.
The tramission has tramission flueds,
Let me know what you think.
Thanks
120,000 miles.
Thanks
i don't think your problem is the clutch, but before you tear into the tranny you should start at the axles and check the splines at both ends and it's possible that the problem may be your CV's. If that all checks good, well, then you may want to consider http://WWW.THEPARTSTRADER.COM or a local salvage yard to find yourself a new tranny unless you want to tear yours apart and rebuild it. i'm not an expert but that's what i'd do.
