Honing Oil - Rehoning procedure
Old Jul 21, 2003 | 02:53 AM
P1mpSlap's Avatar
Default Honing Oil - Rehoning procedure
I'm about to finish up the install on my block.
However, I need to know what type of honing oil is used. I searched and ATF was slightly mentioned. Will StunnaZone ATF brand work just as well? Or should I hit up the Honda Brand ATF?
If somone wouldn't mind guiding me through the aplication process of putting ATF on. I dont want to keep glazing the walls.
Also. Double Check me on this guys..
Up / Down Motion. Doesn't take long. 60 Degree Cross Hatch pattern just to break the glaze off the walls.
Then after I wash the cylinders out, do I imediatly hit it with some WD 40 to keep it from rusting? Or jsut leave it bear metal? (i'm thinking WD 40)
Old Jul 21, 2003 | 04:16 AM
Mr. Choi's Avatar
New User
Default Re: Honing Oil - Rehoning procedure (P1mpSlap)
my shop teacher used solvent, like degreaser. my friend used wd-40. i used marvel mystry oil. you can use
whatever you like.
Old Jul 21, 2003 | 06:24 AM
P1mpSlap's Avatar
anyone else like to shed a more technical insight to this subject matter?
Old Jul 21, 2003 | 08:45 AM
altoid's Avatar
Default Re: (P1mpSlap)
i just douse the hone in engine oil and hone away. I know people that use ATF too, either way its good. I hear the ATF is better cuz you can tell when you've gotten the proper wall texture or whatever you wanna call it
Old Jul 21, 2003 | 09:12 AM
slowdx's Avatar
Default Re: (altoid)
i used mineral oil
Old Jan 10, 2006 | 07:13 PM
mike93eh
Guest
Posts: n/a
use honing oil or kerosene.
Old Jan 11, 2006 | 12:14 AM
Takumi Fujiwara's Avatar
Default Re: Honing Oil - Rehoning procedure (mike93eh)
I used, a machine shop. lol
shawnlee250
Honda Civic (2001 - 2005)
12
Jul 16, 2011 01:44 AM
Razr2
11
Mar 27, 2008 06:25 PM
return_2020
Jun 21, 2005 01:40 PM
shermanyang
Oct 4, 2003 06:17 PM
ceemarun
Jul 12, 2002 02:28 AM
