HELP: can i use obd0 injectors in my obd1 crx si
Old Jul 21, 2003 | 12:13 AM
cRxAuDio's Avatar
Default HELP: can i use obd0 injectors in my obd1 crx si
I converted everything to obd1 (distributor, ecu etc)...currently i have obd0 b16a injectors and was wondering if i can use them or do i have to get obd1 injectors...and if i go with obd1 injectors it wouldnt fit in my stock crx si harness correct? what should i do to get it to fit? and if i can use the obd0 i have to keep my injector box correct...or do i have to get the 92+ injector box? i read a couple of threads on it but still am unclear...any help would be appreciated...thanks in advance
Old Jul 21, 2003 | 12:24 AM
I Want An Si's Avatar
Default Re: HELP: can i use obd0 injectors in my obd1 crx si (cRxAuDio)
if you retain the resistor box you can use them
Old Jul 21, 2003 | 01:43 AM
4crx4me's Avatar
Default Re: HELP: can i use obd0 injectors in my obd1 crx si (I Want An Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Want An Si &raquo;</TD></TR><TR><TD CLASS="quote">if you retain the resistor box you can use them</TD></TR></TABLE>
This is correct.
PM, blown90hatch he's the OBD conversion guru. He can tell you exactly what you need to do.
surkitroller
Dec 29, 2009 12:58 PM
si 1
Mar 10, 2006 05:23 PM
D.Dappa
Jan 18, 2005 06:56 AM
mr. Grind
Aug 13, 2004 04:08 PM
dpine
Jul 14, 2004 06:19 PM
