Can someone help with Wiring Diagram ?
Old Jul 20, 2003 | 07:59 PM
Bspec18's Avatar
Default Can someone help with Wiring Diagram ?
Im making a OBD-II to OBD-I conversion kit i bought (DIY)
And I just wanted to double check that all OBD-II B-series Wiring is the same ? i know that the B18B won't have a knock sensor or a VTEC wires. But i mean the placement of the wires are the same correct ?
Old Jul 20, 2003 | 09:50 PM
Kataku2K3's Avatar
Default Re: Can someone help with Wiring Diagram ? (Bspec18)
Yup everything else is the same... What style of OBD are you doing? OBD2a or OBD2b... Doesn't really matter as all of the pinouts are the same (for each series of OBD) but I was just curious... Just make sure if you have a '96-1998 Civic or '96-1999 Teg that you're making an OBD2a one and for '99+ Civic, 2000+ Teg OBD2b... I don't think you'll have a problem as the jumper is very easy to make... Good Luck
JDM EJ2
Jan 8, 2008 02:28 PM
SoSlo
May 21, 2005 08:47 PM
vtec25
May 14, 2005 01:27 AM
rjardy
Jun 6, 2003 12:16 AM
