did a compression test and didnt get any results
Old Jul 20, 2003 | 06:27 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default did a compression test and didnt get any results
put new rings, pr3 pistons, rod bearings, and stainless valves in my gsr. my car wouldnt start but its getting spark and fuel. when i checked tdc my intake cam was off a few notches (because my dumb *** was in a hurry and didnt put the distributor on right and it held the cam so that the timing belt skipped a couple of notches) so i set the timing back to tdc and did a compression test and got nothing. could i have bent my valves and therefore the valves arent seating properly causing no compression?????? let me know thanks
Old Jul 20, 2003 | 06:40 PM
Fkned2003's Avatar
Default Re: did a compression test and didnt get any results (not so civic)
pos. do a leakdown test to find out. if it leaks from the int. manifold or exhast manifold or headers you bent the valves .
Vladglad
20
Dec 18, 2013 02:56 PM
The Dirty EJ1
Jun 30, 2008 12:37 AM
leeminho86
May 18, 2006 08:14 AM
rasinhell
16
Jun 18, 2005 08:00 AM
