Stripped bolt
How should i remove a stripped bolt on my rear shock???? Are there any tricks?? I have an 88 and i stripped the dumb bolt that attaches the shock the arm. In need some help guys.
thanks
thanks
how bad was it stripped,if it barely stripped,and aint rounded off,you can go to autozone and buy valve grinding compound $4,put it on the bolt and socket and loosen it,i know it sounds weird but try it,the compound bonds to the metal,if not try a vice grip
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch »</TD></TR><TR><TD CLASS="quote">Craftsman makes a thing called Bolt-Out which has "blades" that bite into the bolt and will take it out.</TD></TR></TABLE> I had a stripped bolt and bought the bolt out kit. worked perfectly!
aznryd3r
Apr 25, 2006 08:21 PM
