What fluids do all you recommend?
Old Jul 20, 2003 | 04:22 PM
not133t's Avatar
Default What fluids do all you recommend?
I just got a 98 spec JDM ITR motor (low milage) with lsd and 4.78fd along with everything else. I was wondering what motor oil, tranny oil, etc you all recommend?
Old Jul 20, 2003 | 05:17 PM
EleanoR's Avatar
Default Re: What fluids do all you recommend? (not133t)
Mobil 1 5w30 Synthetic
Honda Genuine MTF
Old Jul 20, 2003 | 05:19 PM
B2FiNiTY's Avatar
Motor oil - Mobil 1 10w30 or Castrol GTX 10w30
Tranny fluid - Honda MTF
Old Jul 20, 2003 | 05:28 PM
vactor's Avatar
you should try Seminal (tm) fluids. i think you'll really like them a lot!!
Old Jul 20, 2003 | 05:43 PM
Ferrell's Avatar
Default Re: What fluids do all you recommend? (vactor)
I just switched to the new Mobil 1 0w-20.
After 2 days of hard driving, and 1 auto-x, I didnt burn any oil.
Old Jul 20, 2003 | 05:53 PM
Asahi's Avatar
Default Re: What fluids do all you recommend? (Ferrell)
Oil: Amsoil 5W-30
Transmission Fluid: GM Synchromesh (Friction Modified)
Brake Fluid: ATE Super Blue
Old Jul 20, 2003 | 06:45 PM
92TypeR's Avatar
FSAE
Default Re: What fluids do all you recommend? (Asahi)
Motor oil - Mobile 10W-30
Tranny - Honda MTF
Brakes - Motul RBF 600
Old Jul 20, 2003 | 08:18 PM
threatcon13's Avatar
New User
Default Re: What fluids do all you recommend? (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">Motor oil - Mobile 10W-30
</TD></TR></TABLE> What the heck is mobile...anyway i recommend mobil1 5w30 and honda MTF...same fluids i use in my 99 jdm itr motor/tranny.
Old Jul 20, 2003 | 08:45 PM
RickV's Avatar
If it is under warranty (although I'm guessing it isn't) then stick with your genuine Honda fluids - I have been told by Honda that they are very picky about this.
Old Jul 21, 2003 | 06:21 AM
not133t's Avatar
Default Re: What fluids do all you recommend? (RickV)
Thanks alot for all the feedback!!
Old Jul 21, 2003 | 08:16 AM
sil's Avatar
sil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Asahi &raquo;</TD></TR><TR><TD CLASS="quote">Transmission Fluid: GM Synchromesh (Friction Modified)
Old Jul 21, 2003 | 09:36 AM
Flux's Avatar
Default Re: What fluids do all you recommend? (sil)
Oil: Mobil1 5w-30
Transmission: Honda MTF
Brake Fluid: Motul 5.1
Old Jul 21, 2003 | 11:13 AM
Hugh Bowie's Avatar
post pics ryan
Old Jul 25, 2003 | 07:55 AM
not133t's Avatar
Default Re: What fluids do all you recommend? (Hugh Bowie)
ill post some when i get a chance. i have to get my test pipe resized, fix my AC because david broke a bolt when he was putting it back in and my throlttle cable is giving me problems also, so when i fix that ill try to get some up for u.
Old Jul 25, 2003 | 08:05 AM
RaVAGE00's Avatar
New User
Oil: MOTUL 300v 5w40
Tranny: Honda MTF
Brake & Clutch: Endless
Rad: Honda OE w/ Water Wetter
Old Jul 25, 2003 | 09:31 AM
Philly_NBP_R's Avatar
Default Re: What fluids do all you recommend? (RaVAGE00)
Oil: Mobil 1 Tri-Syn 15W50
Tranny: Honda Genuine MTF
Brakes: ATE Superblue
Power Steering: Honda Genuine PS Fluid
Coolant: Honda & Water
Headlights: aPc yO!!!
Old Jul 25, 2003 | 10:10 AM
canuckr's Avatar
Default Re: What fluids do all you recommend? (Philly_NBP_R)
Oil: Mobil 1 Tri-Syn 5w-30
Brakes: Motul RBF600
Old Jul 25, 2003 | 10:53 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: What fluids do all you recommend? (canuckr)
Oil: Mobil 1 5W30 (the viscosity recommended in the ITR owner's manual)
Brakes: Cobalt Super XRF
Coolant: Honda Genuine
Fuel: Premium Gasoline (any major brand)
Driver: Diet Mountain Dew Code Red
Old Jul 25, 2003 | 11:00 AM
Spikey's Avatar
Default Re: What fluids do all you recommend? (nsxtasy)
engine oil: Motul 300V 5w40 or 10w40
gear oil (for clutch type LSD): Endless
brake fluid: Endless
Coolant: Motul Anti-gel + distilled water
Old Jul 25, 2003 | 06:10 PM
Phoenix_ITR's Avatar
Default Re: What fluids do all you recommend? (Spikey)
engine oil: mobil1 10W30
gear oil: honda MTF
brake/clutch fluid: motul RBF600
coolant: distilled water and water wetter
powersteering: redline
Old Jul 25, 2003 | 06:46 PM
Spoond TEG's Avatar
Default Re: What fluids do all you recommend? (delinquent)
Anyone ever seen or heard of or used Gear oil for the ITR tranny 75w-90
Is this like SUPER THICK or something? I was just reading in one of my Mags and there was an article that recommend this weight gear oil Just wondering
Old Jul 25, 2003 | 06:48 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: What fluids do all you recommend? (Spoond TEG)
Gear oil is rated using a different scale from motor oil. 75W90 viscosity gear oil is actually similar in viscosity to your everyday 10W40 motor oil. Redline MT-90 is 75W90. Redline MTL is 70W80 gear oil, which is similar to viscosity to your 10W30 motor oil.
Old Jul 26, 2003 | 07:09 AM
Jay J's Avatar
Prince of Zamunda
Default Re: What fluids do all you recommend? (Flux)
Mobil 1 or castrol (I'd say castrol burns less) 10w or 5w30. I'd use 5w30 then if it burns too much go with 10w30. For brake fluid go with Motul 5.1 and for the Tranny fluid go with Honda MTF or mobil 1 tranny fluid
Old Jul 26, 2003 | 07:17 AM
twuelfing's Avatar
my local honda dealer refuses to replace transmission fluid with MTF.
they will only use motor oil. I got into an argment with them service manager and evenetually called honda corporate about it and they didnt care.
I had to ask for like 3 weeks just for them to get some in.
the dealership is hondawest in indianapolis. I would not recommend going there for service.
Old Jul 26, 2003 | 01:42 PM
Jay J's Avatar
Prince of Zamunda
Default Re: What fluids do all you recommend? (twuelfing)
What about ED martin or tim martin in Indiana
