a lil abs question for u guys
Old Jul 20, 2003 | 11:14 AM
social_control's Avatar
Default a lil abs question for u guys
sup h/t...when i first got my car a while back the abs came on one week and has stayed on ever since...i decided to do a bit of brake work n/e ways and thought it would maybe take care of the light but it didn't...heres what i did to my brakes....
new rear rotars, calipers, brake pads
front parts are fine and fluid is new
why is my abs light still on and how the hell can i turn it off...
Old Jul 20, 2003 | 11:19 AM
Bill Hook's Avatar
Default Re: a lil abs question for u guys (Seprioth64)
You need to check the code the ABS controller is throwing out. I've never checked the ABS codes, so I'm not sure if you can ground it out like the ECU.
Probably a bad sensor.
Old Jul 20, 2003 | 11:20 AM
Default Re: a lil abs question for u guys (Bill Hook)
how can i check this code...and how could i be for sure its a censor?
Old Jul 20, 2003 | 12:08 PM
bump
Old Jul 20, 2003 | 12:41 PM
so nobody on this site knows n/e thing about brakes....c'mon i need some help here
Old Jul 20, 2003 | 07:08 PM
HiRevn's Avatar
That happened to me a few years ago. The ABS light came on and stayed on. My ABS modulator was leaking fluid and wasn't pressurizing. Hopefully this isn't the case with yours. It does get pretty costly if you have to replace that thing.
Old Jul 20, 2003 | 07:13 PM
Default Re: a lil abs question for u guys (HiRevn)
my car has no sign of n/e leaks
Old Jul 20, 2003 | 07:40 PM
DSayavan's Avatar
First off, check you fluid level, it might just be that. If not, jump the wires just like you do for a CEL, its underneath the dash on the passenger side. Check the decipher the how many times it flashes, and there's your ABS code. Hope this helps.
Old Jul 20, 2003 | 08:11 PM
vain's Avatar
sign up for team-integra.net
http://www.team-integra.net/se...D=493
Old Jul 20, 2003 | 08:17 PM
GS-R Jay's Avatar
Default Re: (vain)
Yeah check that link for your ABS Code. It's pretty easy to check it. My ABS light was on after I lowered my car and it turned out to be a damaged left rear wheel speed sensor (code 17). It cost me $300 freakin' dollars to have it fixed (part + labor).
Old Jul 23, 2003 | 06:52 AM
tND2k's Avatar
Is there a way to check it for the 94-97 tegs? i checked the T-I.net articles before searching here, and from what I gather, you can only jump wires for ABS codes on 98+.
Seprioth64- d'you find out what that was?
Old Jul 23, 2003 | 07:08 AM
dip-set's Avatar
Default Re: (tND2k)
what fluid is used in the abs fluid resivoir (sp)? brake fluid? os is there an abs fluid thats needs to be purchased... thanks and sorry for the jacking...
Old Jul 23, 2003 | 07:28 AM
Caffeine Slug's Avatar
Default Re: (teg-your-it)
yes, it's just brake fluid
Old Jul 23, 2003 | 07:33 AM
ShowtimesDC2's Avatar
You can jumper wires on integras earlier than '98. My ABS light came on after I changed axles one time. It turns out that in my haste as I cleaned my suspension poarts, I accidentally soaked the right front wheel speed sensor and it ruined it. $100 for a new one. also check your wheel speed sensor ring to see if it might not be aligned on the axle to your speed sensors. hope this helps a little.
Old Jul 23, 2003 | 07:36 AM
tND2k's Avatar
@ SILSRocket - do you jump it the same way you would for CEL flashes? Does that flash you ABS codes also? Where can I find a table for the ABS codes? Would you happen to know if it's the same table that's on T-I.net? If so, I wonder why it's labelled 98+ on there.. confusing! sorry for the 8-million questions..
newhondaowner29
Jan 11, 2006 08:11 PM
jdmlude_dude
Mar 16, 2004 06:01 PM
vtran8
Jul 14, 2003 01:02 AM
vain
Apr 13, 2003 12:40 PM
aLmoSt-vtec
Jul 26, 2001 09:29 AM
