b16a2 mounts in an eg
Rear and tranny side... yes. On the driver side, you're probably using the Integra driver side mount & braket (2 studs that are lined up straight), where as the B16A motor uses a different engine bracket (2 studs are staggered) so you need to either use the stock Civic mount that you originally had before the LS swap, or just swap the timing belt side bracket over from the LS motor to the B16A motor and use the same LS driver side mount.
xxEG6xx
11
Apr 24, 2011 03:54 PM
