what you guys think about Ingall Cmaber kit??
I've had the front camber kit for about three months. The only problem I have is it's noisy (polyurathane bushings). If you get it make sure you lube it up first. Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by espano(ls) »</TD></TR><TR><TD CLASS="quote">no..they suck..get the skunk 2 kit..</TD></TR></TABLE> why do you say that. ive had the ingalls in the front for over a year and its been working fine.
ingalls suck, they create two new dents on my ride. and now the paints are chipping where the dents are.
i have ingalls on the front, sprint (entire arm) on the rear.
sprint is good. cause i got the whole freaking arm.
i also have the pro kit, but imma change it to the H&R OE springs.
got the tokico blues also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Threatcon13 »</TD></TR><TR><TD CLASS="quote"> why do you say that. ive had the ingalls in the front for over a year and its been working fine. </TD></TR></TABLE>
well, depending on how low the car is you might have to bend in the control arms to avoid the control arms from hitting the frame...the skunk 2 is a full upper control arm replacement..but it just depends on how low you go..i've had both and the skunk 2 is a more professional install..
well, depending on how low the car is you might have to bend in the control arms to avoid the control arms from hitting the frame...the skunk 2 is a full upper control arm replacement..but it just depends on how low you go..i've had both and the skunk 2 is a more professional install..</TD></TR></TABLE>
Well that's cool, what happens if he has a DA?
really??? so they are okay i guess, do you guys know by any cahnce if the 91-93 Ingall Cmaber kit would fit on my 95teg?? front and rear??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sPaRk'iT »</TD></TR><TR><TD CLASS="quote">really??? so they are okay i guess, do you guys know by any cahnce if the 91-93 Ingall Cmaber kit would fit on my 95teg?? front and rear??</TD></TR></TABLE>
yea it will fit, someone asked that yesterday i forgot who it was...but they have the exact same part numbers. im buying a set from my friend for 100 bucks (all 4), ill let you know how it goes.
matt94z
19
Aug 8, 2008 06:14 AM
ef4dr
39
Oct 6, 2006 02:18 AM
93b18civic
Aug 21, 2005 07:41 PM
Kidnkorner
28
Jan 12, 2004 03:39 PM
Worked for me
