90 Acura Integra Front brakes on 89 crx si NEED HELP!!
Old Jul 20, 2003 | 12:29 AM
Torino91LS's Avatar
Default 90 Acura Integra Front brakes on 89 crx si NEED HELP!!
Alright. I unbolted the 3 balljoints, swapped brake lines, steering knuckles, rotors and pads. I have a slightly annoying and dangerous problem. My car is lowered 2 inch, and i have a camber kit. the Upper control arm is hitting the frame. I have the Integra ones, Should i put them on and get an alignment. looking at the integra one looks like it would move the arm back away from the frame. Need an answer ASAP. Please help. Thanks in Advance. Please I already know abou the 90-91 EX spindles but here in Lousiana, I have no luck.
Old Jul 20, 2003 | 02:28 AM
Torino91LS's Avatar
Default Re: 90 Acura Integra Front brakes on 89 crx si NEED HELP!! (kincaidcrxsi)
anyone??
Old Jul 20, 2003 | 03:30 AM
bryant's Avatar
I have heard of ppl doing what your talking about no problem. Try and mess with the camber kit a bit and see if that helps. If not, raise your car up.
Old Jul 20, 2003 | 10:47 AM
fourthgenhatchB17's Avatar
Which camber kit do u have? i have a friend with a 89 hatch and his upper arms hit the frame too. He says he has the progress kit but he has black bushings in his. I know for sure im using the progress kit and mine have yellow bushings and i have NO problems. Maybe he somehow bought the car with integra upper arms??? lemme know what camber kit u have...
Old Jul 20, 2003 | 02:20 PM
Torino91LS's Avatar
I'm using a Dropzpne camber kit. I'm going to try install the integra upper control arms and see what happens.
Well i went out and removed the wheels. The passenger side is free and clear of the frame. How ever the driver side is a little close for comfort, you can slide an I.D. card between frame and upper a arm. Tuesday is the earliest I can get an alignement.
Modified by kincaidcrxsi at 11:08 PM 7/20/2003
Old Jul 20, 2003 | 10:02 PM
too bad an alignment wont change the upper arm hitting problem...Only thing that can be adjusted is toe.
Old Jul 20, 2003 | 10:35 PM
Torino91LS's Avatar
well i was looking if anything i'll trim the upper arm
UrbanEh
Feb 1, 2007 03:35 AM
UrbanEh
Suspension & Brakes
Feb 1, 2007 03:34 AM
gnar kill
May 31, 2005 05:28 PM
hybrid1990crx
Jan 19, 2005 04:33 PM
