What tire pressure do you set your kumho 712's at?
Old Jul 19, 2003 | 11:48 PM
PoW3l2BaN's Avatar
Default What tire pressure do you set your kumho 712's at?
Just wondering. Ihave had no luck with these crappy 712's hookin up on the track. They give me 2.4 60' times. ive had pressure anywhere between 25-30psi. What do you guys have then at?
Old Jul 20, 2003 | 06:11 AM
DK4200's Avatar
Default Re: What tire pressure do you set your kumho 712's at? (PoW3l2BaN)
i have the ecsta supra's and yes they are not the greatest but i still can hit 2.3 60ft in my LS. Ive only been to the track once with them so i may be able to hit 2.2. I usually set tire pressure to 22 in front and 35 in rear. What rpm do you launch at?
Old Jul 20, 2003 | 10:03 AM
PoW3l2BaN's Avatar
Default Re: What tire pressure do you set your kumho 712's at? (DK4200)
I dont know what i launch at cause im the second stager. As soon as i get to the staging lights on, the countdown begins. SO i have random launches. Another thing, I dun think i know how to launch in the first place. -=o(
Old Jul 20, 2003 | 10:12 AM
daLixz25's Avatar
try a 4000-4500 rpm slip until your tires grab. at least thats what works for me!
Old Oct 15, 2004 | 10:20 AM
ackerjack's Avatar
when i ran my 711s which isnt the same tire but some idea, i had them at 40 psi and they were gripping good, trying putting in more than 30
Old Oct 15, 2004 | 10:29 AM
dip-set's Avatar
Default Re: What tire pressure do you set your kumho 712's at? (ackerjack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ackerjack &raquo;</TD></TR><TR><TD CLASS="quote">when i ran my 711s which isnt the same tire but some idea, i had them at 40 psi and they were gripping good, trying putting in more than 30</TD></TR></TABLE>
lmao, try droping them down to about 18 20 lbs up front leave the rears alone
normal streets i run my 712's at 34 all around..
Old Oct 15, 2004 | 12:31 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Increasing the air pressure makes the sidewalls stiffer (good for autox, bad for launching) and makes the contact patch narrower.
Decreasing the pressure makes the contact patch wider, as well as increases the total contact patch area. The sidewalls will be softer which helps the tires hook up (notice how drag cars have "wrinkle" slicks with extremely soft sidewalls).
For everyday use you should run the tires at the factory recommended cold pressure settings, regardless of tire size.
Old Oct 15, 2004 | 01:30 PM
xprohx's Avatar
I think too much
Default Re: What tire pressure do you set your kumho 712's at? (PatrickGSR94)
I have 712's in the stock tire size. At the track I had the tire pressure set at 22psi and left the back alone. I couldn't get better than a 2.3 in those damn tires trying different launch points. On the street - its set at the factory specs for maximum treadwear and mpg.
danteisme
Sep 8, 2005 09:32 PM
boosted k20
Oct 1, 2004 11:03 PM
AK94GSR
Feb 9, 2004 02:19 PM
Understeer
Oct 15, 2003 07:59 AM
nEoMuGen
Aug 10, 2001 08:14 AM
