JDM headlight removal...
Old Aug 2, 2001 | 06:21 PM
fast-R's Avatar
New User
Default JDM headlight removal...
Can anyone help me out on this...I need to take out my passenger side headlight (to find a loose wire on the cornermarker bulb), but I can't figure how to get the little bastard out of the car. Are there just the two screw on the top, or is there something else as well?
thanks in advace
[Modified by fast-R, 7:22 PM 8/2/2001]
Old Aug 3, 2001 | 05:58 AM
Benjamin Tang's Avatar
Default Re: JDM headlight removal... (fast-R)
if it's just the corner bulb you do not have to remove the headlight. pull the passenger side fender liner out and see if you can get to the bulb and harness that way thru the wheelwell.
if all else fails you will have to remove the bumper because there is more mounting hardware for the headlight hidden behind it.
Old Aug 3, 2001 | 10:00 AM
Mike M's Avatar
Founding Member
Like Ben said no need to remove the headlight just jack the car up remove the tire and undo the fender liner.
To remove the headlight there are 4 bolts 2 on top 1 on the side of the car mounting it to the fender and a 4th one under the headlight mounting it to a bracket on the rad support
fixitjc
Honda Fit
Nov 27, 2017 08:07 PM
crxaddikt
Nov 3, 2013 10:28 AM
wekiser
31
Mar 29, 2010 11:57 PM
Sassafrass
Honda Civic (2001 - 2005)
Apr 5, 2008 10:06 PM
