squeaking sound when shifting?
Old Jul 19, 2003 | 05:56 PM
00b18b's Avatar
Default squeaking sound when shifting?
ok i drive a 00 integra ls with roughly 22k miles. During normal driving, shifting 2nd to 3rd there is an annoying squeak right after the clutch is engaged. the high pitched squeak sounds like its coming from rear possibly?or maybe the engine somewhere? can someone help me out this is really annoying me
Old Jul 19, 2003 | 06:03 PM
MooreBoost's Avatar
Default Re: squeaking sound when shifting? (00b18b)
Poke your heatshields with a broom, if they squeek, thats your culprit. I had the same prob, and went to a tp and it was gone.
gmoore
Old Jul 20, 2003 | 05:10 AM
00b18b's Avatar
Default Re: squeaking sound when shifting? (tegunderpressure)
thanks ima go check if thats the problem
Old Jul 21, 2003 | 09:58 AM
00b18b's Avatar
nope its not the heat shield..anyone else
Old Jul 22, 2003 | 11:38 AM
4U2NV's Avatar
I used to get an annoying squeaking/clicking noise from my clutch pedal under engaugment, and slightly under disengaugment... I looked under there and found the culprit to be a bad spring located just behind the clutch pedal... I lubed it with WD40 and it went away for a while, but comes back every now and then... HTH...
Old Jul 22, 2003 | 02:25 PM
tub_sephiroth's Avatar
Do what tegunderpressure says, if it doesn't work, lube your slave cylinder, if that doesn't work, it's most likely your throwout bearing. Ouch! I had the same problem, but the dealer was nice enough to replace it under warranty.
Sukii
Oct 19, 2012 07:01 PM
dc5tegk20
Aug 21, 2006 09:36 PM
IsitCosIisBlack
Jun 16, 2006 09:49 AM
Johnny Gasparini
May 27, 2005 06:55 PM
E Swift
Dec 1, 2004 02:57 PM
