Emergency Blinkers work-Turn Signals Don't?What's Wrong?
Old Jul 19, 2003 | 03:17 PM
slvrcivic97's Avatar
Default Emergency Blinkers work-Turn Signals Don't?What's Wrong?
Okay, so I was driving last night and my turn signals decided not to work on me, or my emergency blinkers. Soooo, this morning I looked around and found out that my fuse was blown because the wiring to my sidemarker had shorted. I replaced the wire so no problem right?Well, now my emergency blinkers work, but my turn signals still do not! And I have no fawkin idea on what else to do. I've checked ALL fuses in the car and in the engine bay and none of them are blown. I just wanted to see if anyone here knows what the problem could be because I'm not about to stand in my garage trying to figure it out-not to mentioon the fact that it's 100 fawkin degrees. Sorry for so many "fawkin" words, but I am very frustrated and I DO NOT like driving my car without turnsignals because someone will rear end me. Thanks in advance as your input will be much appreciated. Thanks.
Old Jul 19, 2003 | 05:16 PM
orange.honda's Avatar
Default Re: Emergency Blinkers work-Turn Signals Don't?What's Wrong? (slvrcivic97)
sounds like a relay issue.
Old Jul 19, 2003 | 05:57 PM
Mohudsolo's Avatar
Default Re: Emergency Blinkers work-Turn Signals Don't?What's Wrong? (orange.honda)
The turn signal uses a different flasher unit than the emergency 4ways. Probably the unit died when the wiring shorted.
Old Jul 19, 2003 | 09:16 PM
Default Re: Emergency Blinkers work-Turn Signals Don't?What's Wrong? (Mohudsolo)
Just found the problem!I was missing a fuse that I apparently forgot to check. Everything works A-Ok now. Thanks.
Old Jul 31, 2003 | 07:46 AM
Daemione's Avatar
Just curious - which fuse was it?
nukefivesix
16
Feb 9, 2010 06:51 PM
taimysho0
Feb 6, 2008 09:55 PM
jchrm80
Oct 20, 2007 04:35 PM
atticus184
Mar 15, 2004 02:07 PM
TypeR 599
Jan 19, 2002 11:06 AM
