car super bouncy after energy suspension install
Old Jul 19, 2003 | 11:14 AM
mingchi69's Avatar
I to Smooch Pickle
Default car super bouncy after energy suspension install
ever since i installed the master kit, my car has become unberably bouncy. I even went as far as to get total new suspension (neuspeed koni yellow and eibach prokits). I set the neuspeed koni to the lowest perch and with the pro kits, it still is higher than the sportlines. well anyways, my car is still bouncy, but this time, it's more stiff bouncy than and I cant stand this anymore. I tried adjusting it.. and i can feel the difference, but doesnt solve the bounciness. Is the only thing left to do is to install back stock rubber bushings.
If worse comes to worse, i guess i'll just have to install back the two rear lca bushing and the front lca bushing. that should take care of the ride right?? because the other es bushings are mainly for cornering only and shouldnt have any effect on the ride.
Old Jul 19, 2003 | 11:26 AM
ragejed's Avatar
Default Re: car super bouncy after energy suspension install (mingchi69)
I have the master kit as well...and type r springs...no bouncy here...
Old Jul 19, 2003 | 11:31 AM
mingchi69's Avatar
I to Smooch Pickle
Default Re: car super bouncy after energy suspension install (ragejed)
somebody recommended that i loosen all the suspension bolts.. then drop the car to normal height.. and then retighten it. Is that something you did?? or is it neccesary on these bushings?? I dont think these bushings have preload.
Old Feb 1, 2004 | 07:13 PM
Creep's Avatar
Did you ever resolve this problem?
sounds like you riding on your bumps..
Modified by Creep at 1:53 PM 4/1/2004
mingchi69
Jun 25, 2003 10:44 PM
McLaren
Mar 18, 2002 06:27 AM
civicracer125
Aug 27, 2001 08:09 PM
