PR3 Injector style
I am trying to fin out what style injectors the PR3 ECU runs off of. Does it use saturated or peak and hold injectors. I am building an LS/VTEC and if I dont get RC injectors, I would like ot use Prelude injectors. I have been told that the 97+ Prelude injectors are saturated (High impedance) and they flow at a rate of 290cc/min and the 92-96 are peak and hold (low impedance) and flow at 330cc/min. I will be using these with a CRX Si harness. Does this mean that I will need the injectors plugs from either Prelude harness or will the CRX Si harnes injector plugs work? For those of you that went LS/VTEC, what ECU and injectors id you use?
PR3 injectors are peak and hold style. If you are going to use the Prelude injectors I believe that you need the injector plugs as well. The 92-96 injectors are 310cc/min. HTH.
cyber13
cyber13
uneekcrx
Mar 26, 2002 06:11 PM
