5-lug on a 99-00 Si with ABS
Old Jul 19, 2003 | 06:18 AM
L8apex's Avatar
Default 5-lug on a 99-00 Si with ABS
Question: Swapping a 5-lug conversion from a 2001 USDM ITR to a 99 Civic Si/SiR with ABS. I'm taking both front knuckles and rear trailing arms. Do the ABS wheel sensors stay with the original chassis or can they go with the suspension? Will the sensors plug in once the suspension has been swapped or are they different? Thanks in advance.
Old Jul 19, 2003 | 10:11 PM
L8apex's Avatar
Default Re: 5-lug on a 99-00 Si with ABS (L8apex)
Anybody else done this swap? Or am I in the wrong forum?
Old Jul 20, 2003 | 03:30 AM
visi0n's Avatar
i don't know if you can remove the sensor's off the rear setup. My friend that bought a 5lug conversion we couldn't get the rear sensors off so we just left it on. But in terms of working your ABS should work fine, it basically just monitors for wheel lockup. I would suggest using the stock sensors though but it will probably be the same since its also a honda.
v8killa91
Oct 30, 2006 01:02 AM
snoopy_11
21
Jul 14, 2006 12:17 PM
greebler
23
Feb 13, 2003 09:16 AM
TheHater
Nov 12, 2002 04:01 PM
