will Ground Controls from a 90-93 integra fit 88-91 EF?
Old Jul 18, 2003 | 08:49 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
Default will Ground Controls from a 90-93 integra fit 88-91 EF?
everything has different part numbers so im not sure if they will work. if someone could clear it up for me or point me in the right direction id appreciate it. i couldnt find anything in the search. thanks.
Old Jul 18, 2003 | 10:02 PM
Default Re: will Ground Controls from a 90-93 integra fit 88-91 EF? (fastcrxsi90)
so basically if the rates are 450F and 300R.....
are they the same design, and can i use them just as if they where designed for the crx/civic?
Old Jul 18, 2003 | 11:08 PM
JDMCivicEF9's Avatar
Yeah! O would like to know too! I'm thinking about using 90-93 Integra Ground Control springs as part of my new suspension setup.
Old Jul 19, 2003 | 05:50 AM
Default Re: will Ground Controls from a 90-93 integra fit 88-91 EF? (JDMCivicEF9)
ive seen some people write that 94+ integra is the same as 88+ civic. so is 90-93 integra different or is it also the same?
Old Jul 19, 2003 | 05:56 PM
ok im guessing it doesnt matter. as long as you have the GC sleeves then you can use any GC/Eibach spring as long as its the right height, diameter and rate.
do the 90-93 integras use the same height and diameter spring as the EF?
coreyfrenzel
Oct 13, 2007 06:35 AM
stizzit
Feb 1, 2003 12:07 PM
performula
Jun 14, 2002 07:59 PM
wuhungsixxx
Aug 2, 2001 01:31 PM
