Camber Kit?
Old Jul 18, 2003 | 06:27 PM
Jeff99Base's Avatar
Default Camber Kit?
Im planning on lowering my 99 Base prelude about 1.3 - 1.5 inches at most. I did some searing and found that there is a lot of debate about needed a camber kit at this drop or not. Could some of you that have dropped your prelude this much let me know if you got a kit or not? And if so what kind of kit you would reccomend?
I was thinking of either going with a Ground Control Coil Over Setup or a set of springs, perhaps from Eibach or Tein.
Thanks,
-Jeff
Old Jul 18, 2003 | 06:57 PM
sslude's Avatar
Default Re: Camber Kit? (Jeff99Base)
you wont need a camber kit if you're only looking to 'drop' your car 1.5 inches. i have my car 1.5 inches lower all around and no problems yet. it doesnt look to me like there is any camber needed to be adjusted. BTW, i have progress group sport springs
Old Jul 18, 2003 | 09:18 PM
Casual Gcode1's Avatar
Default Re: Camber Kit? (sslude)
It just depends really because I lowered mine 1.5 and my camber was -2.5 all the way around. After you lower it get your alignment done and find out what your camber is and that will let you know if you need to get one.
Old Jul 18, 2003 | 09:29 PM
Que_Lude's Avatar
I have my 94 lowered about 1.25" or so and have the SPC balljoint camber kit on the fronts only. Didn't want the insides of my Azenis to wear down tooooo fast.
19Accord97
Mar 25, 2009 06:25 PM
JTaudio0212
Honda Civic (2006 - 2015)
18
Oct 25, 2007 04:58 PM
spray_bombed
13
Jul 2, 2007 11:48 AM
ekcivic9
Suspension & Brakes
Dec 3, 2005 08:14 PM
DJ:A
Dec 20, 2001 03:02 AM
