94 accord auto to manual swap question
i am doing this swap to my car very soon but i am confused about one part of this swap. on the 90 to 93 accords have a hole cover with a plate where the master cylinder is supposed to go, but on the 94 version there isint one which mean i must cut a hole? i mean there is a hole but there is a harniss going threw it!! soo my question is how do u mount the master cylinder??? can someone who has done this swap help me. thanks
I'm in the process of doing this now on a 94 accord. I just put in the master cylinder a few days ago. If you look below the hole with the wires you'll see a piece of the firewall padding that you can remove. Underneath is an outline of the holes for the master cylinder. I drilled out the smaller holes with a 3/8 bit and I tried to use a hole saw to cut out the large middle hole but my drill was to big to position at a 90 deg angle so I drilled a smaller hole and used a dremel tool to grind out the rest, it took awile but it worked.
I cut some more of the padding away so the clutch bracket would mount against the firewall but I found that I needed some sort of spacer because the firewall is not flat and the pedal would be too low. I've never looked under the dash of a real 5 speed accord but it must be different, I've heard there is a spacer puched into the firewall.
Right now I just have a couple of pieces of carboard behind the bracket and my pedal height is about 6 inches. Stock height is about 7.5 but the clutch is suposed to release around 5.5 inches so hopefully it'll work. Oh, also I think there is supposed to be a mounting hole above the pedal bracket. Right now I just have to too MC bolts holding it and it seems pretty sturdy.
My bigest problem now is getting the return spring back on the brake pedal, I worked on it most of today and couldn't get it, there just isnt't enough room. If anyone has any sugestions on that I would appreciate it.
are u talking about clutch pedal assiting spring'? if so.....read on
remove clutch pedal pin,,move the clutch master push rod out of the way,now u have free space to snap the assit spring in...
have fun
have fun
email me up ill help ya. I converted my 96 from auto to manual and dropped a h22 in. I kept many notes on wiring and stuff like that.
-Los
apok408@sbcglobal.net
-Los
kylevtecfreak
Jul 26, 2017 06:55 AM
vtec25
Dec 26, 2005 10:12 AM
disposable
Dec 6, 2005 06:53 PM
