ITR vs GTR
Old Aug 2, 2001 | 11:14 AM
MikeH's Avatar
New User
Default ITR vs GTR
Hi all, just a random question. I have some friends who drag every so often, one has a gsr and the other has a type-R. The gsr is a 4dr manual with intake and exhaust. The type-R has an AEM intake and i thikn thats it. But when they drag, the GSR takes the type-R off the line .....they say up till 4th gear, if i remember correctly. The type-R's explination for this is the limited slip diff. Is that it? just wondering.
Old Aug 2, 2001 | 11:18 AM
Big Phat R's Avatar
Default Re: ITR vs GTR (MikeH)
The difference is probably the drivers. Check the time slips - look at reaction time and 60 ft times.
Old Aug 2, 2001 | 11:21 AM
Type Goch's Avatar
New User
actually the LSD shouldn't make a big difference. The Type R should take the GSR off of the launch. Im thinking that the Type R driver does not have that much experience launching it.
Old Aug 2, 2001 | 11:23 AM
EPGONZALEZ's Avatar
Default Re: ITR vs GTR (Type Goch)
yeah..with those mods the gsr shouldnt stand a chance..the type r makes more power and is lighter..its just the driver
Old Aug 2, 2001 | 11:26 AM
Ricehornet's Avatar
uhh, where's the GTR?
Anyway yeah you'd be amaze what a good driver can do in a "lesser" car.
Old Aug 2, 2001 | 11:28 AM
TypeC's Avatar
look at the dyno below:
If you notice, the GSR has a good amount more power (25hp in one place) and a HUGE amount more torque than the ITR until about 6.3K. Even after that, the itr's torque only peaks to what the gsr had earlier (and is almost equal to the GSr torque at 2.5K!!). Having both motors/cars the GSR definately 'feels' faster. That is until 6K comes, then "Hold on to your butts!!" The result of the above race is driver for sure. The GSR no dout would pull in 1st initially, but the ITR has much more reach and tighter gearing. That alone makes a Huge difference.
HTH, -C
Old Aug 2, 2001 | 12:07 PM
Hooch'n's Avatar
Default Re: ITR vs GTR (TypeC)
If you watch the Best Motoring Video they show a GSR getting killed by the type R. From the START. Just .02$
Old Aug 2, 2001 | 12:09 PM
BlackAckeR's Avatar
Tell them to swap cars for one run; that will decide if it's the car or the driver...
Old Aug 2, 2001 | 01:14 PM
ITR571's Avatar
New User
Default Re: ITR vs GTR (BlackAckeR)
every mag youll read will show you R's times in 0-60 are at least 1 second if not more faster than the GSR and 1.5 seconds faster in the 1/4 mile, defintely driver, has to be, R has LSD for better traction on take off, its lighter, and has 25 more Hp, and closer gearing. Driver for Driver the GSR is toast Period.
Old Aug 2, 2001 | 01:43 PM
Racer-X's Avatar
Default Re: ITR vs GTR (ITR571)
Also you need to find out if the ITR driver is having alot of wheelhop or not? If so he need to lower the front tyre presure and that will help. I know it does on mine. matters if your trap speed by about 2mph.
Old Aug 2, 2001 | 01:56 PM
buzzman's Avatar
Default Re: ITR vs GTR (8400-RPM)
8400-rpm: Hey, where do i get to see that Best Motoring video? Looks pretty interesting! :D
-Buzz
Old Aug 2, 2001 | 02:32 PM
SpoonCivic's Avatar
New User
Default Re: ITR vs GTR (buzzman)
Yes I too would like to know how to order the best motoring videos
Old Aug 2, 2001 | 04:00 PM
ninjaman's Avatar
New User
Sounds like the R driver needs to work on his/her skills.
Old Aug 2, 2001 | 04:43 PM
4doortypeR's Avatar
Something is wrong with that Type R. If the Gsr even lauches better because of a better Driver, the R , at least my R plus all the R in Jamaica would easily pass it by
the beginning of 3rd gear. All needs to be done is shift all gears at red line.
A Gsr with intake and exhaust is a easy kill for R, even with no mods.
Old Aug 2, 2001 | 04:48 PM
B18C5's Avatar
Those dyno charts don't take into account the difference gearing makes. I'm not about ot figure exactly what the dif is, but keep in mind that the R's gearing is a fair bit shorter, which will increase the effective amount of power to the wheels, so the difference is actually much less than it seems.
B18Redline
Feb 26, 2011 06:57 PM
JDM_Spec
Feb 27, 2005 04:41 PM
integraracer96
Aug 12, 2004 12:56 PM
acuraownr
Sep 5, 2002 10:09 PM
StinkyTofu
Jul 19, 2001 04:59 PM
