engine problem help
ok so i just started up my b18a after doing the swap. i dont got any codes. but there is a loud tapping sound coming from the engine. what could it be ?
Sounds like you need to adjust your valves man.
Stick a flathead on your valve cover in a bunch of areas around where the valves are... and you will be able to tell if it is your valves tapping...
Let me know.
Let me know.
well i did that screwdriver on hte valve cover thing and it does sound louder near the #1 and 2 cylinder valves, but what i couldnt determine was whether it was coming from the bottom or the top of the motor, but ill try adjust my valves and see what that does, but it does sound like its coming from the back of the motor, more in the intake mani side near the #1 and 2 cylinders
Hmmm... Ya I see what your saying.
Only way I can say is to pull the valve cover off and check to see if the valves are within spec... but remember to adjust them when the engine is cold....
yup its a rod bearing, i took off the #1 rod cap and only half the bearing was there, with metal chunks all over the pickup and baffle
well never really bought a **** motor because i never paid for it yet, the deal was i pay once i get a running motor going. the price to fix the motor is gonna come out of the cost of it
live4speed
11
Aug 18, 2003 01:12 PM
