What spark plug wires are you running?
Old Jul 17, 2003 | 11:22 PM
TRE_'s Avatar
Default What spark plug wires are you running?
Sorry if this is a repost, but I did a few searches and came up with some useless threads. If you know of a good thread about this topic then please post it up!
Right now I'm running OEM wires on my turbo gsr motor(7psi), which seem to be doing ok, but I'd like to upgrade since I'll be installing my MSD setup soon. I was thinking of just ordering MSD wires to keep it consistant, but I'd like to hear what you guys are running and what has worked for you before i order anything. i've heard some good things about Vitek(sp?) wires, but i'm not too sure about them. I trust NGK but I think that there is better stuff out there than NGK for boosted motors. Post up your experinces and recomindations please! thanks in advance!
Old Jul 18, 2003 | 12:33 AM
TRE_'s Avatar
bump y0! any input is appreciated!
Old Jul 18, 2003 | 12:49 AM
_Endless_'s Avatar
Default Re: (glowing_rotors)
i'm using stock honda plug wires and i don't have any problem with it.
Old Jul 18, 2003 | 02:15 AM
Bnjmn's Avatar
Default Re: What spark plug wires are you running? (glowing_rotors)
I did a long search about a month ago...the consensus was that stock/NGK (which is the OEM) are the best...even on super boosted beasts.
Anthony K's Avatar
New User
Default Re: (_Endless_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _Endless_ &raquo;</TD></TR><TR><TD CLASS="quote">i'm using stock honda plug wires and i don't have any problem with it.</TD></TR></TABLE>
Are you using an aftermarket ignition?
Old Jul 18, 2003 | 02:18 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: (Anthony K)
OEM honda on aftermarket ignition.
art
Old Jul 18, 2003 | 02:20 AM
Bnjmn's Avatar
Default Re: (Arturbo)
High fives all around for the 6:15AM crowd!
Old Jul 18, 2003 | 02:21 AM
Anthony K's Avatar
New User
Default Re: (Bnjmn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bnjmn &raquo;</TD></TR><TR><TD CLASS="quote">High fives all around for the 6:15AM crowd!</TD></TR></TABLE>
Heh, 3:15am here in CA.
Old Jul 18, 2003 | 02:26 AM
Bnjmn's Avatar
yeah yeah...but who says you can't get an answer on H-T at any hour?!?
Old Jul 18, 2003 | 02:42 AM
DSF's Avatar
DSF
I'm using MSD wires right now. No problems as far as I can tell. When I change them out I'll either get MSD again or NGK, whichever is cheaper
Oh, and I run a MSD 6AL with Blaster coil.
Old Jul 18, 2003 | 03:22 AM
SiR Kid's Avatar
New User
Default Re: What spark plug wires are you running? (DSF)
NGK wires with an MSD cap and Blaster coil.
I had an NGK wire dryrot and split from the heat in the cylinder head once. Caused a bad misfire because the spark was arcing to the head. It was easy to find, though, because with the car running, I pulled the wire off the spark plug, and you could her it zap zap zapping to the head, and see light fromt he spark plug hole! :eek:
Anyway, NGK still rocks in my book. That plug wire was over 4 years old.
Old Jul 18, 2003 | 04:10 AM
gitwidit's Avatar
Had problems with various other aftermarket wires in the past
Old Jul 18, 2003 | 04:12 AM
BROOD's Avatar
I've always used oem Honda plug wires.
Old Jul 18, 2003 | 04:16 AM
swlabhot's Avatar
Default Re: What spark plug wires are you running? (SLPR)
oem wires and ignition
Old Jul 18, 2003 | 05:06 AM
LEON's Avatar
Default Re: What spark plug wires are you running? (swlabhot)
OEM wires and ignition.... I dont' see the need for aftermarket unless you're really pushing some serious horsepower.
Old Jul 18, 2003 | 05:35 AM
PM-Performance's Avatar
Default Re: What spark plug wires are you running? (LEON)
im all MSD here .
Old Jul 18, 2003 | 08:40 AM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Default Re: What spark plug wires are you running? (itr206)
I'm using NGK with stock ignition right now.
Old Jul 18, 2003 | 09:20 AM
RAWB's Avatar
Default Re: What spark plug wires are you running? (Snafu-Si)
My old Moroso's kept popping off the cap
NGK Blues here REALLY TIGHT FIT
Old Jul 18, 2003 | 09:23 AM
98hx99b18c's Avatar
Default Re: What spark plug wires are you running? (RAWB)
Trevor, probably the OEM is your best bet, also whatever you do...dont use DENSO spark plugs only the NGK.
Old Jul 18, 2003 | 11:10 AM
Pengo's Avatar
Default Re: What spark plug wires are you running? (98hx99b18c)
stock honda plug wires here
Old Jul 18, 2003 | 11:24 AM
romeo619romeo's Avatar
Default Re: What spark plug wires are you running? (Pengo)
MSD.. closest to having the lowest ohms of resistance... besides getting nology.. bout 100 bucks cheaper.. and 50 ohms more resistance...stock honda are alright.. its a decent upgrade for its price.. i did how ever got better trottle response.. doesnt hurt to have less resistance
Old Jul 18, 2003 | 11:31 AM
hawjdude's Avatar
Default Re: What spark plug wires are you running? (romeo619romeo)
i'm using magnecor wires right now but will be switching to nology wires.
Old Jul 18, 2003 | 11:35 AM
turbochic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">OEM honda on aftermarket ignition.
me too, no problems here
Old Jul 18, 2003 | 11:36 AM
psileepR's Avatar
New User
OEM
Old Jul 18, 2003 | 11:41 AM
RGAZ's Avatar
New User
Default Re: What spark plug wires are you running? (Civtek)
No problem with NGK OEM.
But I run Magnacore 8.5MM Competitions on two of my cars and have over 75,000 combined miles on them without any problems at all.
I also run MSD 6BTM and Blaster 2 coil and found no problems with Magnacores or NGK's.
Get what you want, they really don't make much of a difference.
Randy
