clutch questions . . . .
hey there its your old buddy jay bouchard again . .so my clutch is bad , im going to be just replacing the clutch not the PP or anything else . . . i have a XTSS ACT clutch .. . . im wonder is it ok to mix and match manufactors of clutches and throwout bearings and piolit bearings along with a diff pressure plate
im thinking about a dif clutch manufater , like clutch net with there EXTRA STRONG spring retainers . . . thats what i keep blowing on my clutches is the spring retainers , and then a spring pops out and i cant get out of gear anyway any help would be great thanks
JAY
edit BTW i have a friend selling a stage 3 CENTERFORCE with a twin disc design , i dotn know much abotu it , but he said 300 cash and i was like i'll think about it . . . i really need help please i have to eitheer buy my friends clutch ( will everything included) or buy a clutch from someone and have my car done by the 25th of july ( have to drive 4 plus hours for fam , and done have a diff car to drive there in)
thanks again
JAY
Modified by jason bouchard at 3:02 AM 7/18/2003
Modified by jason bouchard at 3:06 AM 7/19/2003
JAY
thanks again
JAY
save time and confusion, just buy a whole clutch with everything. spend the extra couple 100 or so. i would say clutch master stage 3. Very nice clutch, it can hold lots of power, and it still has a rather soft pedel pressure.
how about the clutchnet stage 3 with a twin disk . . . i dont have the money for a full clutch ***. plus i just did the install of the ACT like 5 months ago , and i also want the pedal to be hard , liek it is now with the ACT
i dont have the money and i like the hard pedal that i have now from the act XTSS . . . so , should i buy just the SS clutch disk and retry that , or buy the clutch net . . . or what ?? thanks
JAY
JAY
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jason bouchard »</TD></TR><TR><TD CLASS="quote">i dont have the money and i like the hard pedal that i have now from the act XTSS . . . so , should i buy just the SS clutch disk and retry that , or buy the clutch net . . . or what ?? thanks
JAY </TD></TR></TABLE>
How the hell did you blow up a SS disc? Did you install it correctly? What is your driving style like?
JFYI, when you install it, you must use extra bolts to bolt the pressure plate to the flywheel (if you use the prolite flywheel) for a total of 9 bolts. Otherwise the pressure plate is not balanced correctly.
I've never heard of Clutch Net producing a TWIN Plate clutch.
http://www.clutchnet.com/make/acura.html
Otherwise $300 bux would be a steal considering that competiting Twin Plate Clutches like Excedy and Tilton cost upwards of $1400 bux.
If you are blowing the clutch up b/c you dump the hell out of it every day, maybe you need something beefier. Try a ACT 6 puck or a Clutch Net 6 puck unsprung.
ok, so wait , if i have a stock lightend flyweel i would need to put more bolts in the pressure plate? for the ACT XT PP ??¿
my drving style is driving like an *** alot , or atleast sometmes . . .
act is crap you can hold them on with duct tape. my suggestion the, exedy hyper single clutch. all the weight is centered rather than dispersed, the clutch material is ceramitallic, the clutch itself is sprung so you won't bust your knee or blow your master and slave cylinder on your clutch and the clutch will hold up to 500hp at 15,000 rpm. not to mention oem fit and no additional parts being necessary make this clutch kit one of my best selling acura/honda clutches
EDIT :: the clutch that my friend is selling is the
Vendor CENTERFORCE (C78)
Part # DF900800
Description DUAL FRCTN SET - SEE APPL
Notes FOR A COMPLETE SET ORDER ONE (1) OF EACH PART NUMBER LISTED. FIRST NUMBER IS CLUTCH & PRESSURE PLATE ASSEMBLY, SECOND NUMBER IS THROW OUT BEARING.
Tech DOES NOT HAVE CENTERFORCE WEIGHTS DUE TO BELLHOUSING CLEARANCE.
Retail $467.68 (300 from my friend)
Availability IN STOCK
Part # DF900800
that's not a twin-disc clutch, i think the term Dual Friction just applies to the friction material used on each side of the clutch disc.
You would not be able to use a twin-disc clutch anyway unless you changed your pressure plate, as they require a specific pressure plate to be used with those type discs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jason bouchard »</TD></TR><TR><TD CLASS="quote">ok, so wait , if i have a stock lightend flyweel i would need to put more bolts in the pressure plate? for the ACT XT PP ??¿
my drving style is driving like an *** alot , or atleast sometmes . . . </TD></TR></TABLE>
ACT Recommends that you use all the mounting points/holes to secure the pressure plate. Pending application. I believe the Stock GSR flyhweel has 6 bolts to hold it on. If you are spreading the bolts out and torqing to spec, you should be fine.
However, "driving like an ***" does not define any sort of driving style.
Do you drive hard? Daily drive commutor? Drag race it? Road Race it? You get my point.
I still think the problem was installer error. Was your pressure plate damaged by the disc? When my springs exploded out of the disc, it ripped up my pressure plate. There was no way in hell I could've reused it.
yea , i daily redline and chirp , 2nd and if i wanna i can do 3rd and 4th . . . i go daily about 100mph
im thinkin about buyin my friends clutch for 300, it comes with everything i need . . . . its a twin disc clutch btw . . . . the one up /\ there with all that info
anyone used it , is it daily driver style ? i dontr have much done . runnin about a 14.7 or so (i/h/c/e ) one day i wanna be more . alot more prob turbo . . . i just dont wanna have to buy anouther clutch after this for a good year atleast (wishful thinkin)
ok my friend said its that maker of the disk i havent seen it yet but he said its a 2 disc setup(twin disc) stage 3 type and its fully sprung . . . anyone no what im talkin about for a 94 gsr stage 3 centerforce with twin disc . . . .
pearl
Apr 18, 2006 03:40 PM
