A question about Type-R seats
When you pull on the reclining lever on the passenger side seat to let people in, does your seat automatically slide foward? When I pull the lever, the seat doesn't pull foward and you have to pull the other lever below the seat to slide it foward for people to get it. I just find that a little odd because I think my 99 GSR slid foward when you pull the lever.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type-Rizzle »</TD></TR><TR><TD CLASS="quote">When you pull on the reclining lever on the passenger side seat to let people in, does your seat automatically slide foward? When I pull the lever, the seat doesn't pull foward and you have to pull the other lever below the seat to slide it foward for people to get it. I just find that a little odd because I think my 99 GSR slid foward when you pull the lever.</TD></TR></TABLE>
Your seat has had the cable that allows that fall off. Remove the seat and look on the bottom, it should be obvious.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface »</TD></TR><TR><TD CLASS="quote">Your seat has had the cable that allows that fall off. Remove the seat and look on the bottom, it should be obvious.</TD></TR></TABLE>
What he said...you may be able to fix it without taking the seat out.
