CAR WONT START! I NEED SOME HELP/ADVICE!
Old Jul 17, 2003 | 09:22 PM
oOPreludeBoyOo's Avatar
Default CAR WONT START! I NEED SOME HELP/ADVICE!
My car will not start. i recently installed a Jackson Racing Supercharger in my car and when the install was all finished the car didnt start. The engine turns and the spark plugs are sparking, and the injectors are working as well, but it just wont start. Its been three weeks and no mechanics know whats wrong! some people say its the ECU but we checked the taps and everything is hooked up fine! Any advice? Please HELP ME! Thank You!
Old Jul 17, 2003 | 10:13 PM
Nice_Dc2r's Avatar
Default Re: CAR WONT START! I NEED SOME HELP/ADVICE! (oOPreludeBoyOo)
ground wires
Old Jul 17, 2003 | 11:56 PM
salbaje's Avatar
check all fuses in the engine compartment, wiring and grounds
Old Jul 18, 2003 | 08:14 AM
bump!
Old Jul 18, 2003 | 11:25 AM
Audipwr1's Avatar
Default Re: (oOPreludeBoyOo)
air fuel spark is what makes her run
check order of firing to be correct
check to make sure fuel is in the cylinder
check to make sure iac is working
even with a broken ecu if those are all workng then itll start
Old Jul 18, 2003 | 11:32 AM
turbochic's Avatar
Default Re: (Audipwr1)
timing also could be an issue, if your dizzy's off or cam is off, maybe timing belt could be wrong. had the same prblem, had fuel, had spark, and had air, found that the timing belt was off two teeth
Old Jul 20, 2003 | 03:06 AM
Bump
Old Jul 20, 2003 | 08:11 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oOPreludeBoyOo &raquo;</TD></TR><TR><TD CLASS="quote">Bump</TD></TR></TABLE>
What have you checked so far?
SeanWard
Feb 21, 2009 04:09 PM
91daINTEGRAda91
Apr 5, 2008 04:32 PM
dc2doi
Jan 6, 2008 01:43 PM
boobie1721
10
Dec 18, 2007 03:56 AM
Lo-Buck EF
Aug 22, 2003 05:40 AM
