Bad Camber - Need Suggestions?
Old Jul 17, 2003 | 06:31 PM
JDMCivicEF9's Avatar
Default Bad Camber - Need Suggestions?
A friend of mine got a 94 Prelude DOHC VTEC that he just bought and his main concern is that the rear wheels look like this / \ from behind. What can he do to correct it? Is there like a low cost alternative, like for ex: using washers just like a Civic to correct camber. Or do he need a camber kit? Which camber kit do you guys recommend?
Old Jul 17, 2003 | 07:05 PM
user 9782082308's Avatar
Default Re: Bad Camber - Need Suggestions? (JDMCivicEF9)
I know you can't use washers on '88 and up Preludes. The 3g you can slot the bolt holes for the ball joint and make it adjustable. On the 4g and 5gs you'll just have to shell out the $$$.
Old Jul 17, 2003 | 08:58 PM
Default Re: Bad Camber - Need Suggestions? (racerx)
Anybody else got any answers?
Old Jul 18, 2003 | 08:16 AM
Casual Gcode1's Avatar
I have the 3572 kit on my 5th gen but if the camber is not to bad then the 3570 will work.
http://www.lightningmotorsports.com/ingalls.htm
vietherbs
May 28, 2006 09:46 AM
fafsa
Apr 6, 2005 03:41 PM
itsJDMyo
13
Jan 7, 2005 10:40 AM
bb2prelude
Aug 26, 2002 08:03 PM
