h22 all motor w/ oversize valves?
Old Jul 17, 2003 | 06:14 PM
civicsitek GanGsTa's Avatar
Default h22 all motor w/ oversize valves?
I just pulled my head apart and found out that my ferrea valves are actually 1mm oversize. I was planning on running skunk2 stage 2's with my set up but skunk recommends against oversize valves. My engine setup is
h22 block
h23 crank
h23 rods w/ arp bolts
h22 type s pistons
arp head studs
ferrea +1mm oversize valves
ferrea springs
ferrea ti retainers
type SH cams (want to swap out)
imagine engineering header
intake manifold converted to single stage
balance shaft elimanator
Any cams that work with oversize valves or should I stick with the type sh? This will be a street car that gets taken to the track every now and then. Rev limit will be about 7500. Any thoughts?
Old Jul 17, 2003 | 07:52 PM
J2turbo21's Avatar
Default Re: h22 all motor w/ oversize valves? (civicsitek)
Over sized valve dont gain and even lose power according the the alaniz website.Also if you go with a very high lift cam there is a possibility that the valve will hit each other.
Old Jul 17, 2003 | 10:16 PM
kwik93si's Avatar
Default Re: h22 all motor w/ oversize valves? (J2turbo21)
I have fererra 1mm oversize in my h22 right now but I'm switching them out for stock size valves, since I'm using crower stage 3 cams, and crazy high compression very soon.
Old Jul 17, 2003 | 10:34 PM
eg:R's Avatar
how did you convert your h22 intank man. to a single runner?
Old Jul 18, 2003 | 02:41 PM
Rob Dizzle's Avatar
stock valves are fine. you wont gain anything from going with oversize valves.
KISS
go with stock oem valves
Old Jul 18, 2003 | 04:29 PM
Default Re: h22 all motor w/ oversize valves? (Bob-DC2)
so oversize valves in h22 lose power? Is this because of a stock port not profiled to the bigger valve?
Old Jul 19, 2003 | 12:53 AM
ApexiAccord's Avatar
Default Re: h22 all motor w/ oversize valves? (jacklee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jacklee &raquo;</TD></TR><TR><TD CLASS="quote">how did you convert your h22 intank man. to a single runner?</TD></TR></TABLE>
take out he secondary butterflys
Old Jul 19, 2003 | 02:21 AM
J2turbo21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob-DC2 &raquo;</TD></TR><TR><TD CLASS="quote">stock valves are fine. you wont gain anything from going with oversize valves.
KISS
go with stock oem valves</TD></TR></TABLE>
Just curious what KISS means?
Old Jul 19, 2003 | 10:01 AM
ShoeGuy#1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J2turbo21 &raquo;</TD></TR><TR><TD CLASS="quote">
Just curious what KISS means?</TD></TR></TABLE>
Keep it Simple Stupid...
rumo1112
Feb 6, 2011 06:27 PM
92JDMCB7
Apr 14, 2009 04:28 PM
SiR-T
Aug 8, 2006 04:38 PM
NewOrleansH22
May 7, 2005 09:36 AM
Rick Solis
Oct 26, 2004 11:09 AM
