code 7,14 and rev- limit @ 2500...
Old Jul 17, 2003 | 05:19 PM
JurakS's Avatar
Default code 7,14 and rev- limit @ 2500...
I just did a zc swap, and dx to zc engine harness conversion. AFter driving for about a minute or two, i get a rev limiter @ 2500rpm and codes 7, 14. I switched out 2 tps sensors. And the IACV valve looks fine. Anybody got a clue as to what is wrong?
Thanks.
Any help is greatly appreciated.
Old Jul 17, 2003 | 06:56 PM
Turbogixxer's Avatar
Default Re: code 7,14 and rev- limit @ 2500... (Juraks)
With the TPS, Put the key in the On/Run position. grab a voltmeter and test the Red/blue wire. It should be .45 volts at idle and 4.5 volts at WOT. If not try adjusting it, if that does not work then you will have to replace it.
For the IACV, take it off the car and take some carb clean and clean it out.
See if that works.
Old Jul 19, 2003 | 07:21 PM
essinem4130's Avatar
I just swapped out my ECU with a chipped one, and when I put my stock one back in it threw 7 and 14 also... Tried resetting it, nothing, took the thing off the back of the intake manifold, cleaned it out... Same thing, replaced TPS... Still nothing... I don't get it.
Old Jul 20, 2003 | 03:12 PM
eg_type_r93's Avatar
chipped ecu = mabe burts out rom in ecu
661rex89si
Apr 12, 2011 01:04 AM
crxracerde
Jul 10, 2010 03:39 PM
billyanderson
Oct 2, 2009 12:16 PM
dad0c402
May 5, 2007 08:06 PM
rschoener
Aug 17, 2003 08:48 AM
